that's not too appealing since it won't store the track titles by itself
Huh?
test.cue:
PERFORMER "Asura"
TITLE "Lost Eden"
FILE "test.flac" WAVE
TRACK 01 AUDIO
TITLE "Lost Eden"
INDEX 01 00:00:00
TRACK 02 AUDIO
TITLE "From The Abyss"
INDEX 01 00:10:00
TRACK 03 AUDIO
TITLE "Raindust"
INDEX 01 00:20:00
x:\metaflac --import-cuesheet-from=test.cue test.flac
x:\metaflac --list test.flac
METADATA block #0
type: 0 (STREAMINFO)
is last: false
length: 34
minimum blocksize: 4096 samples
maximum blocksize: 4096 samples
minimum framesize: 14 bytes
maximum framesize: 11909 bytes
sample_rate: 44100 Hz
channels: 2
bits-per-sample: 16
total samples: 10619280
MD5 signature: 225c44ec444da8c8e769c963156148aa
METADATA block #1
type: 3 (SEEKTABLE)
is last: false
length: 486
seek points: 27
point 0: sample_number=0, stream_offset=0, frame_samples=4096
point 1: sample_number=438272, stream_offset=991673, frame_samples=4096
point 2: sample_number=880640, stream_offset=2008363, frame_samples=4096
point 3: sample_number=1318912, stream_offset=3022910, frame_samples=4096
point 4: sample_number=1761280, stream_offset=4044032, frame_samples=4096
point 5: sample_number=2203648, stream_offset=5088504, frame_samples=4096
point 6: sample_number=2641920, stream_offset=6165196, frame_samples=4096
point 7: sample_number=3084288, stream_offset=7227440, frame_samples=4096
point 8: sample_number=3526656, stream_offset=8270779, frame_samples=4096
point 9: sample_number=3964928, stream_offset=9310350, frame_samples=4096
point 10: sample_number=4407296, stream_offset=10347465, frame_samples=4096
point 11: sample_number=4849664, stream_offset=11421948, frame_samples=4096
point 12: sample_number=5287936, stream_offset=12452504, frame_samples=4096
point 13: sample_number=5730304, stream_offset=13480053, frame_samples=4096
point 14: sample_number=6172672, stream_offset=14518782, frame_samples=4096
point 15: sample_number=6610944, stream_offset=15539189, frame_samples=4096
point 16: sample_number=7053312, stream_offset=16582873, frame_samples=4096
point 17: sample_number=7495680, stream_offset=17642699, frame_samples=4096
point 18: sample_number=7933952, stream_offset=18675827, frame_samples=4096
point 19: sample_number=8376320, stream_offset=19762450, frame_samples=4096
point 20: sample_number=8818688, stream_offset=20830942, frame_samples=4096
point 21: sample_number=9256960, stream_offset=21880676, frame_samples=4096
point 22: sample_number=9699328, stream_offset=22923194, frame_samples=4096
point 23: sample_number=10141696, stream_offset=23854449, frame_samples=4096
point 24: sample_number=10579968, stream_offset=24295082, frame_samples=4096
point 25: PLACEHOLDER
point 26: PLACEHOLDER
METADATA block #2
type: 4 (VORBIS_COMMENT)
is last: false
length: 40
vendor string: reference libFLAC 1.2.1 20070917
comments: 0
METADATA block #3
type: 5 (CUESHEET)
is last: false
length: 576
media catalog number:
lead-in: 88200
is CD: true
number of tracks: 4
track[0]
offset: 0
number: 1
ISRC:
type: AUDIO
pre-emphasis: false
number of index points: 1
index[0]
offset: 0
number: 1
track[1]
offset: 441000
number: 2
ISRC:
type: AUDIO
pre-emphasis: false
index[0]
offset: 0
number: 1
track[2]
offset: 882000
number: 3
ISRC:
type: AUDIO
pre-emphasis: false
index[0]
offset: 0
number: 1
track[3]
offset: 10619280
number: 170 (LEAD-OUT)
METADATA block #4
type: 1 (PADDING)
is last: true
length: 7576
x:\
could you please show me where are the track titles are stored after embedding the cuesheet? coz i see no occurence. foobar will only show the name of the 'parent' file for each track. you can only solve this by introducing custom tags, which is, again, 'exotic' -> see the next paragraph
and i'd like to avoid exotic tagging stuff to resolve it
What's "exotic" about an embedded cuesheet?
what exotic about that is that very few of the apps support cuesheets, and even fewer support embedded ones.
