old kode54 vs new kode54, the only one without halving volume. Difference range of 0.0000026 to 0.0000153 should be interpreted accordingly.
Differences found in all track pairs.
Zero offset detected in 6 out of 6 non-identical track pairs.
Comparing:
"C:\£V03\01 ~ Larks' Tongues in Aspic, Part One.wav"
"G:\£V03\01 ~ Larks' Tongues in Aspic, Part One.wav"
Compared 35959140 samples.
Differences found: 6090809 values, starting at 0:00.104807, peak: 0.0000026 at 10:00.564195, 2ch
Detected offset as 0 samples.
Comparing:
"C:\£V03\02 ~ Book of Saturday.wav"
"G:\£V03\02 ~ Book of Saturday.wav"
Compared 7755720 samples.
Differences found: 456573 values, starting at 0:00.033651, peak: 0.0000011 at 2:47.675488, 2ch
Comparing:
"C:\£V03\03 ~ Exiles.wav"
"G:\£V03\03 ~ Exiles.wav"
Compared 20324220 samples.
Differences found: 776787 values, starting at 0:00.052721, peak: 0.0000014 at 0:02.798934, 1ch
Comparing:
"C:\£V03\04 ~ Easy Money.wav"
"G:\£V03\04 ~ Easy Money.wav"
Compared 20859300 samples.
Differences found: 969334 values, starting at 0:00.024603, peak: 0.0000087 at 3:17.769456, 1ch
Comparing:
"C:\£V03\05 ~ The Talking Drum.wav"
"G:\£V03\05 ~ The Talking Drum.wav"
Compared 19650960 samples.
Differences found: 5789500 values, starting at 0:00.000000, peak: 0.0000060 at 2:09.109615, 1ch
Comparing:
"C:\£V03\06 ~ Larks' Tongues in Aspic, Part Two.wav"
"G:\£V03\06 ~ Larks' Tongues in Aspic, Part Two.wav"
Compared 18840696 samples.
Differences found: 1294054 values, starting at 3:51.635601, peak: 0.0000153 at 6:50.609546, 1ch
hdcd.exe (the .wav.hdcd.wav files) vs new kode54, close except track 5
Comparing:
"C:\V03\01.wav.hdcd.wav"
"C:\V03\01 ~ Larks' Tongues in Aspic, Part One.wav"
Differences found: 8375504 values, starting at 0:00.104626, peak: 0.0000031 at 0:05.395986, 1ch
Comparing:
"C:\V03\02.wav.hdcd.wav"
"C:\V03\02 ~ Book of Saturday.wav"
Differences found: 790220 values, starting at 0:00.033651, peak: 0.0000021 at 0:00.284966, 2ch
Comparing:
"C:\V03\03.wav.hdcd.wav"
"C:\V03\03 ~ Exiles.wav"
Differences found: 1003446 values, starting at 0:00.052721, peak: 0.0000025 at 0:05.212608, 1ch
Comparing:
"C:\V03\04.wav.hdcd.wav"
"C:\V03\04 ~ Easy Money.wav"
Differences found: 1314510 values, starting at 0:00.024603, peak: 0.0000041 at 3:17.882993, 1ch
Comparing:
"C:\V03\05.wav.hdcd.wav"
"C:\V03\05 ~ The Talking Drum.wav"
Differences found: 7811623 values, starting at 0:00.000000, peak: 0.0004261 at 0:00.005850, 2ch
Comparing:
"C:\V03\06.wav.hdcd.wav"
"C:\V03\06 ~ Larks' Tongues in Aspic, Part Two.wav"
Differences found: 1435872 values, starting at 3:51.635601, peak: 0.0000073 at 6:50.370000, 1ch
That improves a tiny bit over the fairly close comparisons hdcd.exe vs. old kode54 - same issue with track #5:
Comparing:
"C:\£V03\01.wav.hdcd.wav"
Differences found: 8582736 values, starting at 0:00.104626, peak: 0.0000026 at 10:55.775986, 1ch
Comparing:
"C:\£V03\02.wav.hdcd.wav"
Differences found: 805810 values, starting at 0:00.033651, peak: 0.0000024 at 2:47.694104, 2ch
Comparing:
"C:\£V03\03.wav.hdcd.wav"
Differences found: 1047606 values, starting at 0:00.052721, peak: 0.0000024 at 0:05.137075, 1ch
Comparing:
"C:\£V03\04.wav.hdcd.wav"
Differences found: 1352023 values, starting at 0:00.024603, peak: 0.0000057 at 3:17.770113, 1ch
Comparing:
"C:\£V03\05.wav.hdcd.wav"
Differences found: 7964942 values, starting at 0:00.000000, peak: 0.0004264 at 0:00.005850, 2ch
Comparing:
"C:\£V03\06.wav.hdcd.wav"
Differences found: 1484115 values, starting at 3:51.635601, peak: 0.0000091 at 6:50.608889, 1ch
CUETools I am getting more problems with ...
