Hi there,
the sort default is preferences->columns ui->filters->behavior -> sort tracks added when to a playlist by ?
I have %album artist% - %album% - %discnumber% - %tracknumber% - %title%
I mean this rules when i use album list or quick search or drag a bunch of files in foobar2000 ,don't it?
I believe that is only default sorting for CUI filters. Other components have their own preferences page, where you'd probably have to edit each one.
I would like a sort like artist -> album date -> track number and title (song name)
For using CUI filters, you could just add %date% to the above -
%album artist% - %date% - %album% - %discnumber% - %tracknumber% - %title%
I have file path=%path_sort%;artist=%artist%|%date%;album=%album%|%discnumber%|%tracknumber%;track number=%discnumber%|%tracknumber%;title=%title%
If i want to change to have artist ,album date onlder to newer (1976-1978-1980) , tracknumer and title should I change to ..?
%<artist>%|['['%date%']' ]%album%|[%tracknumber%] - %title%
No, it should follow the syntax. This is only for manual sorting from the Edit > Sort menu, or right-click playlist tracks > Sort context menu. Have a look at that menu and you can see the entry for each "template" that is referenced in the settings, each one is separated by semi-colon. So to change Edit > Sort > 'by artist' menu template, modify the artist= part -
artist=%artist%|%date%|%album%|%discnumber%|%tracknumber%|%title%;
Complete entry -
(Preferences > Advanced > Display > Standard Sort Patterns)
file path=%path_sort%;artist=%artist%|%date%|%album%|%discnumber%|%tracknumber%|%title%;album=%album%|%discnumber%|%tracknumber%;track number=%discnumber%|%tracknumber%;title=%title%
(I'm not sure this is necessary, it might sort fine with defaults)
Cheers
