Topic: Columns UI (Read 4602493 times) previous topic - next topic
Columns UI
Reply #6100
This isn't an issue of columns ui but is caused by hidden folder.jpg files.
These files are created by WMP when you played MP3 or MP4 files with embedded album art with it.
Search in your folders for these hidden folder.jpg files and delete them (enable the hidden files in windows explorer options to find them).
Columns UI
Reply #6101
^Thanks. For some reason I found image files with system file attributes so I couldn't see them even when showing hidden files. I have no clue where they came from but are all gone now.
Columns UI
Reply #6102
Hey guys! I didn't want to post this into the support forums as I have only one simple question about columns UI and its configuration capabilities.
I have a simple configuration as shown in this picture.
I have 3 grouping categories like this:
1.) [%artist%]
2.) [%album%] ['('%date%')']
3.) [%disc%]
Everything's working swell but it would be nice if I would be able to hide the little-horizontal-ruler-thingy when a track doesn't assigned to an album or when an album is not multi-disc. The picture I linked clearly shows my little concern. Is there a way to overcome this?
Columns UI
Reply #6103
You can use something like this, i.e. "$if2(%disc%,$tab())" so that at least HR wont show, but that's unfortunately all I guess you can do about it
Columns UI
Reply #6104
Hmm... it's a same, but I have to live with this. :) No biggie ofc. Maybe in a new version of the plugin or something like that. Anyway, thanks for your answer!
Columns UI
Reply #6105
while this won't solve it, you can add something on the other end of the $tab() to make things look a little nicer.
here is my setup. top is a regular album, and below it is a multi-disc.
Columns UI
Reply #6106
I have been having some trouble with Columns UI, the filters never show anything; Is there any way to fix this? I am running Windows 7 64bit.
(Click to enlarge).
Columns UI
Reply #6107
Any library viewer would be empty if you haven't configured your media library
Columns UI
Reply #6108
How could you align the texts "Disc 1", "Disc 2" with the left edge of the album art? I have tried $crlf() but it doesn't do anything.
Columns UI
Reply #6109
So how do I do that?
Edit: Nevermind, I worked it out. Thanks for the tip .
Columns UI
Reply #6110
i put a manual space in front of it to move it over to the right a bit, but i'm not sure if that's what you're asking...
[ Disc %disc number%]
[: %disc title%]
$tab()
$upper(%genre% | %style%[ | %country%]  )
Edit:
looking again at your post perhaps you're asking how i got a second line? just create a new grouping script below your first one.
just be aware that groups will get sorted by whatever you use...
Columns UI
Reply #6111
Hello!
Is there a way to make volume and position controls thinner (lower) when put on a separate row of a toolbar?
Columns UI
Reply #6112
hi
i can't run foobar with the 3.8.7 version, says to re-run the foobar installer
3.8.6 works
Columns UI
Reply #6114
[: %disc title%]
$tab()
Edit:
How do you add country string?
Columns UI
Reply #6116
this was mentioned before but.. Is it possible to get rid of an outline which appears on an active item when CTRL is pressed? This happens on both Ng playlist and playlist manager.
Columns UI
Reply #6117
This is a nice setup. How did you get the Codec Type and that stuff next to the image. Im assuming its another column. But whats your code like.
~Amish
Columns UI
Reply #6118
Found it. Using the $select function.
Also I want to ask. In a skin such as this.
The icons at the top such as the Wikipedia Icons and so on. How do you go about getting the icons to show up like that. Im assuming you use the foo_run library to open the corresponding webpage. But I'm not sure about how to get the images to show up.
Columns UI
Reply #6121
I initially posted about new 0.3.8.7 version, but it seems I wasn't informed by foo_autoupdate about new cui version
[edit] Great improvements
very minor issue: If Ctrl-C is associated in keyboard shortcuts it won't copy selected fields from item properties
Columns UI
Reply #6122
I dont know how exacly expain this problem but i try it...
When i click to some item in Album List - the item sends to NG playlist (And to "library view" in playlist manager). I play some music and the music is market as currently playing, when the music ends - the next one begin to play. But when i click to another artist, the NG playlist rewrite. Soon in old version when i click back the previous artist, the playing song is still marked as playing, but now in new version the rewriting make a new list of music - i mean, the currently playing song is not market as playing anymore. It's like the same list of song changed in "library view". Then when the music ends, the aplication doesnt know what is next song, so it's start some random song...
Please, how to set up to stay curently playing song keep to market as playing during changing "library view" and "ng playlist" in the same time.
I use to UI Columbs as the plugin...
Thank you
(sorry for my bad english)
Columns UI
Reply #6123
(I use ColumnsUI)
Hi.
I have no clue about the scripts of foobar, I'm not really interested into custamizing foobar so much, so that my research would do me any good in the future. I tried to custimized it a little, and I got it all except for one thing.
In my playlist, when the song is played, it is highlighted with the text color white, and the background in red. However, when I highlight other song (but the previous one still being played), the playing song goes back to the original style of every song on the playlist.
I'd like it to stay the same no matter if I highlight other songs or not. I already changed the background that is changing a little (grey instead of black) but this problem ^^^ is a little over my head.
Could anybody help me with that ?
To sumarize. I want the played song to stay the same (white font - red background) no matter what I'm doing, whether it was selected automaticly when the song changed to this one, or I'm selecting other songs - but not playing them).
My script:
$if(%_themed%,,$if($and(%isplaying%,$not(%_is_group%)),
$ifequal($mod($if2(%_display_index%,%list_index%),2),0,
$puts(back,$offset_colour(%_back%,$calculate_blend_target(%_back%),12))
$puts(back-selected,%_selected_back%)
$puts(back-selected-no-focus,%_selected_back_no_focus%)
$puts(back-selected,$offset_colour(%_selected_back%,$calculate_blend_target(%_selected_back%),7))
$puts(back-selected-no-focus,$offset_colour(%_selected_back_no_focus%,$calculate_blend_target(%_selected_back_no_focus%),7))
$puts(back,%_back%)
$set_style(back,$get(back),$get(back-selected),$get(back-selected-no-focus)))
Columns UI
Reply #6124
Is it possible to make the second group (Disc number) conditional, so that when there is only one disc the second line (blank space is not created?
