Topic: foo_openlyrics (not my release) (Read 35246 times) previous topic - next topic
Re: foo_openlyrics (not my release)
Reply #100
I recently upgraded to 1.8, and no longer see lyrics for any song. I can see them in search, I can see them in tags, but they simply display blank or (if I click "search") read "parsing..."
Anybody else having this behavior?
Reply #101
Hi there,
is there a way to show (and save) only synced lyrics.
On my 1.7 it shows always unsynced lyrics., In the manual search here are lots of synced ones.
thx bkh
For this, you can use the Lyric Show Panel 3 plugin. This plugin allows you to search and display song lyrics from various sources including Google, Musixmatch and Genius.
Reply #102
I got an issue when upgrading to 1.7, not resolved in 1.8: https://github.com/jacquesh/foo_openlyrics/issues/315
It seems to be due to a second panel.
Reply #103
Is there a way to change the format of the saved local file name?  I see the default, but it was not clear to me if that could be modified.
I'm trying to make the file names compatible with my Sony Walkman.
Reply #104
What is this fix malformed timestamps? How does it work?
Reply #105
When I use Album Art for the background, it disappears on track change.   Any clues?
fb2k 2.1 / CUI 2.1 / Open Lyrics 1.8
Reply #106
Hey, I don't know if I'm missing something, but how do I access the customization settings? When I right-click the panel I can select Edit lyrics, or Preferences which takes me to a black page that has a checkbox for Debug logging enabled and nothing else.
and
Reply #107
@aelklirion  The little arrow on the left to unfold the menu?
X
Reply #109
The only feature that this plugin lacks (and foo_uie_lyrics3 does not) is the ability to scroll the lyrics manually while it is scrolled automatically. That is, I do need automatic scrolling but sometimes I also need to be able to scroll the lyrics manually - without changing preferences of course.
Magically yours
Raistlin
Reply #110
From Github it seems he plans on including Bandcamp and LRCLIB for new sources in version 1.10.  Those are top choices for me--if SongLyrics were included too it would be a clean sweep.
Functionally I'm still hoping the source ID of the lyrics can be displayed at the top of the results so we know what's coming from where, and can adjust our search priority accordingly.
Yes I have posted about all of this on the project's Github site.
Reply #111
Is there a reason that a space is added in between any paragraphs? Even if i copy the lyrics into Notepad, remove the spaces, and paste them back into the OpenLyrics editor, the next time I open the editor the spaces have returned.
Also, the cursor ends at a new line rather than the last character? Seems like characters are being added behind the scenes.
Reply #112
Most song lyrics from most of the sources and plugins I've used will show separated paragraphs, which to me makes the lyrics much more "readable" than just one mass of text and I believe in most cases is what the artist intended/wanted anyhow--how many lyrics on LP liner notes have you seen that did NOT have a space between paragraphs??  If you really don't want it though just go into the "Auto-Edit" panel of the plugin and choose "Remove all blank lines":
Reply #113
I don’t think I explained it clearly. I’m not talking about the space between the verses. But in that paragraph break there is an actual “space”, as if somebody hit the spacebar on the keyboard.
So even though I’m typing:
Verse 1 > Enter > Enter > Verse 2
It’s acting as if I typed:
Verse 1 > Enter > Spacebar > Enter > Verse 2
In addition, it’s acting as if I hit Enter on the keyboard again at the very end of the lyrics, even though I haven’t.
Reply #114
Hello there! First of all I want to thank you for your great work and masterpiece!
I am wondering if it is possible for you to make the font of the main text somewhat customizable! I think it would be great if the main text (the line that is being singed) would appear bigger or even different than the passed or upcoming lines!
thank you in advance!
Reply #115
Have you tried some of the options in its Fonts & Colours section (Prefs->Tools->OpenLyrics->Display)?
Reply #116
Hey friends, I'm using OpenLyrics 1.9 with the newest Foobar install (just started using Foobar)
It says that it can pull the lyrics from Genius as a source but when I manually search lyrics, Genius never shows up even though Googling it shows Genius does have lyrics for all these songs. Am I doing something wrong? This is what my Foobar panel looks like in Preferences.  https://files.catbox.moe/bqmal9.png I didn't see how to attach images to the post, sorry.
Reply #117
When you create or reply to a message, below the message window is a bar that says "Add files by dragging & dropping or selecting them."  Click on "selecting them" and browse to the image(s) you want to attach.
Are you doing this:
1.  Right-click file in the playlist and choose "Openlyrics -> search for lyrics (manually)"
2.  Search starts automatically; check for "Genius" in the "Source" column of the search box;  clicking it will the display the lyrics from Genius.
Reply #118
Okay I was using the quick reply function before, so I didn't know this reply box existed. But uhhh, there's no "source" option here.
Reply #119
If as your first image showed, "Metal Archives" is NOT in your left "Search order" box of chosen sources, then the option "Search for options (manually)" must be ignoring the chosen sources and by default doing a search using ALL sources.  I agree that is not expected behavior, and should be considered a bug.
I encourage you to report this to the developer's github site as a bug report at:
https://github.com/jacquesh/foo_openlyrics/issues/new/choose
He requires examples so when making out the report just use the example you've described here--post an image showing the selected sources table, and then the results you get when doing the manual search.
If you've never used Github before it requires a simple username/password login setup with an inital emailed confirmation link.  No big deal and well worth the access you then have to ANY account there that allows user input.
