Topic: QAAC: discussion, questions, feature requests, etc. (Read 701347 times) previous topic - next topic
Reply #950
Okay, I just ran makeportable again and it worked. What the hell. Not complaining.
Got the 64 bit version running under Foobar too. What is up with you, Windows.
Reply #951
This new version uses ICU 5.5 (icudt55.dll). A minimal version:
Reply #952
^  Much appreciated! Thanks!
Reply #953
I have a problem with Qaac > 2.51.
I use the following command line to encode my files:
Tools\qaac\qaac64.exe -V 45 -q 2 -N -d Temp Temp\*.flac
Using 2.51 it works as expected. But with version 2.52 and 2.53 I get the following error although qaac64 --check shows the libFLAC.dll
qaac 2.53, CoreAudioToolbox 7.9.9.6
ERROR: Not available input file format
Do you need any additional info?
Reply #954
Unfortunately, not reproducing here. Also, no relevant change comes to my mind...
Difference between 2.51 and 2.52 is tiny. Only 3 commits:
https://github.com/nu774/qaac/commit/458d21...9187a690bc5e064
https://github.com/nu774/qaac/commit/699e07...6732d12b0d71b96
https://github.com/nu774/qaac/commit/68ef0c...a77fbe65aeb4746
Can you isolate the condition of  the failure?
Reply #955
Sorry, I'm not very good at C++ but I see that the changes have to do with the path.
I guess it's that QAAC cannot load/find the flac dll file in the newer versions although they are located in the qaac64 exe folder. Using only wav files works without problems with the same command line:
Tools\qaac\qaac64.exe -V 45 -q 2 -N -d Temp Temp\*.wav
EDIT: Or are there possibly errors because of a new build chain as I see that errors for MSVC14 are fixed? I'm using the 64 bit flac ICC dll from rarewares.
Reply #956
How do you place qaac64.exe and libFLAC.dll? If you replace qaac64.exe (not working now) with an older one in the same path, and the older version works? Then it's unlikely that only new version cannot locate / load libFLAC.dll.
2.52 is built with the same compiler as 2.51 (MSVC12), so it's not relevant (2.53 is built with MSVC14 though).
Reply #957
Everything works here with qaac 2.51 and 2.53 with 64-bit libFLAC from rarewares.
Reply #958
After some trying reproducing it I noticed that v2.52 fails only for files bigger than 2 GB. If you want I can give you my sample and environment that can reproduce it.
Reply #959
Well, does 2.51 succeed on the same file?
Reply #961
I checked 2.52 binary, and found that it was actually compiled with MSVC14. So, my memory was wrong.
It might have something to do with it.
Reply #962
I sent you my environment to reproduce the error as a PM.
Reply #963
I built qaac64 2.52 myself (with VS2013 u5, and also with VS2010) and it works with 2.3 GB FLAC file.
Reply #964
It seems that fstat() of new Universal CRT introduced on VC14 now fails when the file in question is larger than 2GB, so we have to always use _fstat64() instead.
Actually, qaac was using fstat() only to test if it's a seekable regular file, so file size returned by fstat() was insignificant. However, new fstat() implementation hates to silently return incorrect value when the size doesn't fit in 32bit integer.
Reply #965
Ok, then I'll use 2.51 till there is a fixed version, thank you for your help.
Reply #966
I thought that 2.54 is the fixed version.
Reply #967
Sorry if I asked before, how can a 3KB empty/dummy DLL replace a 24MB DLL? Does it still work? The encoder doesn't need it? Thanks.
Reply #968
icudt55.dll contains no code, only data for ICU ("International Components for Unicode").
"The default ICU data consists of the data needed for the converters, collators, locales, etc. that are provided with ICU." -- http://userguide.icu-project.org/icudata
Apparently qaac/refalac doesn't use any function of CoreAudioToolbox that require these data to be present.
Indeed...
Reply #969
Ah, I didn't notice that there is a newer version already. Thanks.
Reply #970
I have the exact same problem with FLAC files and the x86 build: v2.51 works but versions 2.52 and above all fail, using the same QTfiles portable folder and just changing Qaac.exe.
I'm on XP and the FLAC files I've used for testing are about 4 and 16 MB.
Reply #971
Are we talking only about Windows XP? Because here on Win 8.1 qaac 2.54 works perfectly with flac files, testes right now.
Reply #973
With the same error message?
Yes:
BTW same behaviour with Wavpack DLL.
Do you use XP SP3?
No I'm on SP2. Because I had troubles with some -not so recent but I like it- musical hardware and some of their drivers I had to revert back to SP2 years ago.
MSVC14 requires SP3 ? Well, encoding from WAV works fine so I can live with it
