Topic: Bigger icons without columns ui (Read 3719 times) previous topic - next topic
Is there a way to have bigger icons for the play/pause etc buttons without using columns ui?
Increase the font size.
Did you try this and it worked??
What Font size change adjusts an image size.
terry
Adjusting the font size didn't work. Any other suggestions? ...please
The only way afaik is to increase the DPI in windows.
If you have a visual impairment which makes the current buttons unusable, it's probably not a bad idea.
Cheers.
elevatorladylevitateme
