Topic: foobar2000 for mac (Read 132880 times) previous topic - next topic
Re: foobar2000 for mac
Reply #300
Just switched to fb2k on macOS as I am sick of streaming services having me by the balls. It's definitely come a huge way since I last tried it so thanks very much for putting the work in. Hotkeys would be absolutely lush, not so concerned with the visual aspect as I am not such a customisation nutter these days and don't generally spend my time staring at a music player, but yeah again fab work :)
Reply #301
Is it possible to unsort a playlist? After clicking on, say, title header to sort by title, I'd like to unsort so the playlist is back in the original order that the tracks were added to the playlist).
Reply #302
Save the playlist before you sort it, then re-load from the saved playlist.  Or perhaps just "undo".
Something I've had to get used to is that a playlist is not a play order.  The concept is to present the user with a shortlist of tracks from which to select.  If using the list to play in a specific sequence (which seems natural to me, and the option is available to play in sequence), make sure you've saved it.
Reply #303
I see. Thanks
Reply #304
Petition to have "Library View Selection Playlist" as a feature in the next update ? <3
