Topic: foobar2000 0.9.3.1 (Read 28806 times) previous topic - next topic
foobar2000 0.9.3.1
I guess he hasn't tried it yet (I was surprised about this behaviour, too). Additionaly you can't select the text via the mouse, at least this is a minus.
Um... Yes, you can.  Just right click on the field you want.
I believe he means selecting blocks of text using the cursor, not a bruteforce rightclick-and-click field-by-field selection.
I concur with darky about this being a minus. I use special file infobox for this, but why would anyone need 2 plugins with the same features to get the job done? Adding this feature into the default one just about completes the featureset for the Properties system.
foobar2000 0.9.3.1
What do you mean about selecting blocks of text? I can select one kind of blocks of text if i click and hold on empty space (not on text) and drag the selection box over the lines I want to copy and then rightclick.
foobar2000 0.9.3.1
For example,
When I want to copy from the Properties>General>Duration field, I can only copy "2:34.424 (6810095 samples)" as the smallest selection possible.
I am unable to select just "6810095" for my intended use.
Edit: I have already tried out every feature, hidden or not, described by all the helpful posters about the new Properties dialog. I am certain that it is not possible to select individual letters or blocks of text.
foobar2000 0.9.3.1
That's true. Overall usability is still better with the new properties dialog IMHO.
foobar2000 0.9.3.1
The new properties dialogue is a big step forward. There is just one thing I don't like about it. Foobar2000 shows fields even if they are empty. It would be better if Foobar2000 would just show fields containing data. Sometimes when I ripp CDs and don't enter genre or date there are empty fields I later can't delete because I don't know they exist.
foobar2000 0.9.3.1
Reply #30
Selecting text in the properties tab will be possible in the next release.
You can define which fields are shown by default at the advanced preferences.
Leave "standard fields" empty to display existing fields only, or just remove "Date=DATE;Genre=GENRE;".
I don't see why it's such a big problem though. Entering values is so much faster with the new dialog.
foobar2000 0.9.3.1
Thanks for your tip, Frank.
foobar2000 0.9.3.1
Hold shift when activing "Properties" to acess the tab directly.
Or, you could redo your context menu altogether.  Scrap 'Properties', and replace it with 'Properties (metadata tag)' and 'Properties (properties tag)', if you're really worried about that extra effort pressing the shift button.
There is also a hidden column that displays the files name that is useful when editing multiple items.
AAAAAAAHHHHHHHHH!  I'm going freaking crazy trying to find this.  Please someone help an idiot out.
Sorry about reviving this dead thread.
foobar2000 0.9.3.1
Reply #33
Properties > Metadata tab
right-click a field name, click Edit, Individual Values tab
click on the separator between the column headers # and <fieldname> , drag to the right
foobar2000 0.9.3.1
Reply #34
Shit.  This whole time, I thought the column was on the metadata tab.  Thanks Cosmo.  Big help.
