lossy archiving
Reply #48 – 2008-05-28 21:55:18
One says musepack is good for transcoding, the other one says vorbis is the best one. I think there will be no clear winner, *cause every lossy codec has its problems with transcoding, and I also think this is unavoidable. I believe the test to which de Mon refers is this one . The test scope was limited, so its results should be considered accordingly. And you're right to say there's no clear winner, other than the LAME MP3 version used in the test not generally being a good transcode source. Vorbis had the highest average score, but it looks to me like it's probably within the error margin with at least the MPC encoder. The other person's claim is skirting a TOS#8 violation. Yes, I meant exactly this test and I had mentioned it was 'little' test. Anyway, I think the rational way would be lossless or MP3 V2 (despite you have player which plays other codecs). Despite I use Ogg Vorbis as lossy, the quality of sound is not the main gain for me. I like Ogg Vorbis's for: 1. replay gain tagging possibility 2. encoding speed (Lancer's compile) 3. tags 4. true gapless playback 5. FREE and open source 6. quality per kbs ratio Yes, quality at the last place despite it is very very good codec. Anyway I can listen my Ogg Vorbis files without transoding everywhere except my car.But if someone wants compatability - better use MP3 (LAME at V2) and don't bother with spending time on transcoding.
