Topic: foo_youtube (Read 164670 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
Re: foo_youtube
Reply #925
Any reason why after installing this, components about box, and probably another dialog box shows some glasses effect behind them? I'm using Windows 10. Regards :)
Re: foo_youtube
Reply #926
I cannot imagine any reason for this. Are you sure it is foo_youtube? Have you tried clean foobar2000 installation (e.g. separate portable installation) with only this component additionally installed?
Re: foo_youtube
Reply #928
Thank you for the video and for further details. This bug should be fixed in current beta.
Re: foo_youtube
Reply #929
Thank you for fixing it. I can confirm it looks fine now. Regards :)
Re: foo_youtube
Reply #930
Youtube > Copy > URL doesn't have a mnemonic. Maybe assign a number (&1, &2)?
Re: foo_youtube
Reply #931
I have troubles using external ffmpeg from zeranoe builds win32 shared.
Have own directory for each component.
14:05:23, [warning] could not load external ffmpeg: C:\Users\NIN9\Portables\foobar2000\libs\avutil-lav-56.dll: 56.15.100 > 56.0.0
14:05:23, ffmpeg: lavf 57.71.100, lavc 57.89.100, lavu 55.58.100 (internal)
14:05:23, VSFilter 1.7.1.322 1.7.1.322 (external)
14:05:23, LAV Filters: LAV Splitter 0.71.0.34 (external)
14:05:23, LAV Filters: LAV Video 0.71.0.34 (external)
14:05:23, libcurl/7.59.0 WinSSL zlib/1.2.11 (external)
Re: foo_youtube
Reply #932
@Hidrojen
Well, I am surprised that other menu items have access keys. So, foobar2000 adds them if menu does not have its own access keys. And when URL item turn comes, all three letters are already taken by the above items. Fixed in the latest version.
@NIN9
Latest ffmpeg version is "too new" for the component. ffmpeg API changes with time, and these changes are not always back-compatible. So component has to limit max ffmpeg version. This limitation was added in 2.3.1. Previous versions most likely will crash if you would try to use new ffmpeg with them.
Re: foo_youtube
Reply #933
Thank you for explanation and great coding. Happy everything works as intended so far.
SimplePortal 1.0.0 RC1 © 2008-2018
