Topic: Columns UI appearance (Read 3292759 times) previous topic - next topic
0 Members and 6 Guests are viewing this topic.
Reply #1375
Updated....
it may be released b4 Sept.~i'm not sure...i've a lot of work to do... my test...
@empty45:
nmm,i'm also interested in the combination of these 2 works...
mad messy misanthropist morbid mused
Reply #1376
Thats my simple config.
Reply #1377
My config, just the way I like it.
Seekbar and Volume WSH code from MonoLite.
Reply #1378
Here is my new skin called Ribbon UI and it is available here:
The skin is in beta version. A txt file is there to explain how customize the ribbon easily. It would be interesting if the project becomes a collaborative work so I rely on other users in order to complete the ribbon with new commands !
Reply #1379
Wow! This is kinda amazing, will try this
Reply #1380
Sorry if I'm missing something incredibly obvious, but is there a place where I can download some premade layouts like these?
Reply #1383
That's a really great skin! some bugs/suggestions:
1. Every time I launch foobar, this package resets the playback order to default. And I'd like it to stay at 'repeat playlist';)
2. I can't seem to get it how to get my custom button for tagging with Discogs to apply it to the whole current selection. When I try to tag  some files using my custom button, only the first file (or the file that is playing now!) is passed. I'm running the command with
fb.RunContextCommand ("Tagging/Discogs/Write Tags...")
3. It'd be nice if I could open a panel with the album art:) I tried to look at the code for showing the library, but it isn't clear for me. I'm not experienced in jscript.
Reply #1384
Also, it'd be nice to be able to resize the library window.
Reply #1385
For Playback order, the problem is fixed and will be available in v.1.3. For Discogs masstager, I never used it but can you send me the script you used before ?
Reply #1386
recently I've finished my new skin, but there is one thing that is bugging me and I don't know how to deal with it. Maybe someone from here can help.
When I launch foobar, the NG Playlist is cut from the bottom (pic on the left), then when i try to resize foobar window, NG Playlist automatically fill the gap (pic on the right). When i close foobar and lauch it again the gap in the bottom is the same, what's wrong??
Reply #1387
How do you force the layout of your playlist, in the tab PanelList or in Script with $movepanel ?
Reply #1389
Eh ok problem solved, all i had to do is lock the Playlist. Here is the final skin:
Reply #1391
Looks nice, mind sharing it?
Here you are, I did some minor changes and add a collapse button. Here's the LINK. Although the collapse button has 1 bug, when you close foobar collapsed and start it again, not a big thing but still. If it's a problem just comment the collapse button script in splitter settings (easy to find).
Here how it looks:
Reply #1392
Same as above +Explorer tree button
LINK
Reply #1393
Thanks for sharing, azureone.
Reply #1395
I get this error when launching your skin.
Scripting Engine Initialization Failed (GUID: A4001E9B-77D4-4A99-9630-26E748374DEA, CODE: 0x80020101)
Check the console for more detailed information (Always caused by unexcepted script error).
Caused by the WSH Panel Mod.
Reply #1396
Have you read the comments on deviantart ? You can test the installation in portable mode and if you want to install it in standart, make sure to copy the configuration folder in the foobar path as explained by 4kiba. Hope it will help you.
Reply #1397
I've updated mine so it doesn't use any images.
Reply #1399
Worked perfectly.
Very nice set-up. The only thing I'm not understanding is "Cursor follows playback". Doesn't do anything for me... whatever it is supposed to do.
