Topic: Improving foo_playcount for 0.9 (Read 179525 times) previous topic - next topic
Reply #125
thanks for all the help but i will wait until a newversion comes out or g-lite says the component is stopping development
Reply #126
Modifying this component so that it works with .93 is not dependant on G-Lite doing the work.  When G-Lite ported this component to .9, he included the source code.  Therefore, anyone can take a stab at modifying this component to work with .93.  I would, if I could.  Hopefully, someone will take on this project.
Reply #127
Hopefully someone will fix this plugin when .93 has reached final.
Reply #128
Terrestrial has updated the unofficial playcount so that it now works with .93 beta 4 as it did with .92.  Download it here.
Reply #129
@Stuart60611:
where did you find out about this? i tried searching for a post regarding this release and i couldn't find it.
Reply #130
@Stuart60611:
No formal release and just a quick update.
Reply #131
@Stuart60611:
No formal release and just a quick update that was done gratuitously.
Oh. Just Wondering.
Reply #132
woohooo great work thanks for the update!!
Reply #133
thanks. working perfect here
Reply #134
So what's the difference between this and the official one? The formatting of certain first time plays etc. and play_count vs play_counter
Reply #135
this one will automatically tag the files, it also uses first_played.
Reply #136
um? i use the 'offical' one and if you check an option in the advanced section it tags it during playback..
(how else does it tag it?)
Reply #137
in  that case, it will add a first_played tag. and you can specify what percentage of the track plays before it is tagged.
Reply #138
Thanks for the update!
Reply #139
Hi, i have made a fresh install of Foobar 0.9.3 and loaded the playcount plugin from the link above (http://users.bowie-cass.com/singa/foo_playcount.zip).
After starting Foobar i've got the following error message:
Failed to load DLL: foo_playcount.dll
Reason: Diese Anwendung konnte nicht gestartet werden, weil die Anwenungskonfiguration nicht korrekt ist. Zur Problembehebung sollten Sie die Anwendung neu installieren.
Quick translation:
"The application could not be started because the configuration of the application is not correct. Please reinstall the application"
Does the plugin only work with beta versions of foobar 0.9.3 ???
Has anyone tested the plugin with 0.9.3 final ?
EDIT:
I found another download here:
http://sg.tistory.com/category/Tool
2. foo_playcount.dll (비공식 버전)
http://stephan.kochen.nl/proj/foo_playcoun...o_playcount.dll
플레이 횟수가 %play_counter%, 최종 재생일시가 %last_played% 첫 재생일시가 %first_played%,
파일에 기록된다. 다양한 조정 옵션이 있다. 업데이트되는 순간 태그 기록창이 뜬다.
Installed and the DLL got loaded.
But it doesnt write any Tags !!!
I configured it to write tags after 1% playtime but nothing happens....
greets
Splat`
Reply #140
Quick translation:
You have to install the VC2005 runtime or you can install .NET 2.0 runtime if you like (VC2005 runtime included).
Reply #141
Woo hoo awesome.  The update made the metadb handle leaks go away.
Reply #142
Great! Thank You!
Now it works how its supposed to be
The only annoying thing is the popup window when the playcount tags get updated... hope there will be a workaround for this in the future
Reply #143
greets
Splat`
Thanks to visit my blog (http://sg.tistory.com) Splat`
If you wanna playback info write tag (to file)
Use foobar 0.9.3 & New Offical foo_playcount.dll 1.2 (http://foobar2000.org/components/foo_playcount.zip)
and must add file to media library
(if you don`t use media library, Offical foo_playcount.dll doesn`t write tag)
Reply #144
Well... I can not read a single word on your blog but thanks for your help
The Official plugin is useless for me because i need the FIRST_PLAYED tag for the "hotness" script.
All i have missed to install is the VC2005 Runtime, thuan has found the solution
Reply #147
Maybe if you want to set the time it will write the tags. The official one writes it after one minute.
Reply #148
Sure! The unofficial plugin has some options more.
But do they describe a realistic scenario? If i just like to prehear a track i don't need more than one minute. And if i listen to a song more than one minute i will probably listen to the end.
Reply #149
nevermind.
