Topic: Album Art Downloader (Read 473460 times) previous topic - next topic
Reply #50
First been using this soft qll dqy long to find covers, just love it.
Yet there is one thing i would love to do with which is not currently that easy. I would like to find artist photos using this soft.
I see two choices:
If you have a collection sorted by artist/album, we could have a browser only by artist saving art in the artist directory . Yet this wouldnt work for compilation. Or we could save all artists art in one directory.
The other idea would be to use tags to browse that way anyone could use his collection.
Alexvallat: do you think it is possible?
Reply #51
There's already a script for FofR's artist image service included in v0.5: artists.trivialbeing.boo.
There isn't any specific support for saving artist images with a different scheme to album images at present, although I suppose that might be something to consider for future versions.
Alex
Reply #52
Alex
Yes i saw that script and that s i thought about it. I think finding a way to deal with artists art would be like the real bonus of album art downloader(even if it goes against its name  ).
Thanks for your work. Couldnt live without this little piece of software now
Reply #53
The programm doesn't start on my computer. It always says there is as problem
Reply #55
k so i have a question all my music is in d:\music\ but i store my album art to c:\album art  is there an easy way for me to get it to search the music in d:\music and have it save to c:\album art?
Reply #57
AlexVallat:
Would it be possible to have proxy settings. Currently i cant use this at work. Thanks
Reply #59
AlexVallat:
It uses the system proxy settings. Go to Control Panel, Internet Options, Connections, Lan Settings, and fill in your proxy server settings. They will then be used by Album Art Downloader.
If you can't do that, or you need to set separate proxy settings for some reason, then open the AlbumArt.exe.config file in the Album Art Downloader program folder. Add to the end of it, just above the </configuration> end tag, this XML:
<system.net>
  <defaultProxy>
    <proxy proxyaddress="your proxy address" />
  </defaultProxy>
</system.net>
more details...
Incidentally, this method can be used with any .net application (and if you are really cunning, you can set it up as a machine or user-wide setting).
Alex
Do you have the .net runtimes installed?
Yes I have . Netframework 2 installed so I really don't understand what is the problem
Then I don't know either, sorry. You could try uninstalling, re-downloading and reinstalling, in case something got corrupted somewhere along the line. Or you could try posting the exact error text, I'll google it and see if something turns up.
Reply #60
I am willing to do that but I got all the messages in german. I hope I will translate it right then
But I try uninstalling and then installing
Reply #61
anyone have an answer for this?
Reply #62
This is Marc's feature, he might have a better answer for you, although I know he is very busy with other matters at the moment.
As far as I can tell, the browser searches for a file with the Default Art Filename set in the options, in the same folder as the music file is found. This makes it unsuitable for your requirements, because the filename of the album art is not constructed from the ID3 tags of the music file, so there is no way to find it in another folder.
Alex
Reply #63
Alex
As Alex just mentioned I am currently busy with my two new baby twin girls.
Additionally my main computer is broken and I just have an old laptop. As soon as possible I will work on the tool again. I have a nice list of todos and ideas.
Marc
Reply #64
AlexVallat:
<system.net>
  <defaultProxy>
  </defaultProxy>
</system.net>
more details...
Just discovered a strange thing that might be the source of the problem, i dont have a config file. I looked in the program folder as in my application data folder. Nothing.
I have tried to change settings to force the creation, nothing. i have rights to create in this folder so dont really see why it isnt created... any idea?
Reply #65
My run settings are:
"C:\Arquivos de programas\foobar2000\utilities\AlbumArtDownloader\albumart.exe" "%artist%" "%album%" "$replace(%_path%,%_filename_ext%,)cover.jpg"
But I still get the artist/album/path spaces blank :/
-foobar2000 + Burrrn + EAC
-HD 80Gb using High QualityVBR MP3s
Reply #66
Check the first post for the current commandline switches for the newest version.
Reply #67
Huh, OK, guess it must be sticking the config file in isolated storage then.
Nevermind, you can just create a plain text file with the name AlbumArt.exe.config in your album art program folder (next to the .exe), and put the text:
<configuration>
<system.net>
  <defaultProxy>
  </defaultProxy>
</system.net>
</configuration>
in it, and it should work fine.
If you want to find the per-user config file for whatever reason, it should live in:
\Documents and Settings\user name\Local Settings\Application Data\Marc_Landis,_Alex_Vallat\AlbumArt.exe_Url_random junk\version number\user.config
You could also add the <system.net> element to that, if you prefer.
Reply #68
So here is a translation of my "failure window":
Album Art downloader has recognised a problem and must be shut down.
Does someone knows an utility to copy the hole infomations because Copy and paste won't work
Reply #69
How about using Alt+PrtScr to capture a screenshot of it?
You said you tried uninstalling and re-installing AlbumArt Downloader, did you use the latest 0.6 version to re-install?
Alex
Reply #70
Alex
Marc
no worries understandable life comes before computer stuff:) even a simple thing that if it even saved in the directories the music is in if you can save it in a %artist% - %album% deal so then u can just goto windows search and search for *.jpg in the music section then just cut and paste all the covers to the directory they are all stored in.
Reply #71
Hi Guys,
I'm new to Album Art Downloader, although I have been using its predecessor (Coverartdownloader) with REACT2. I've now managed to get this newer version working in REACT2 and have found it to be a big improvement  .  Anyway, I've got 2 questions:
1.) Is it possible to change the order in which the returned results are displayed? For example, how can I get the results from Amazon to show up before the results from GoogleImage?
2.) Is it possible to limit the results by image size? For example, how can I get the scripts to return images no smaller than 300x300 pixels?
Thanks in advance,
- p
Reply #72
Hi Phaedra,
To change the order the results are displayed, go to File, Settings, Script Manager, and use the Up and Down arrows to move the sources you want to use into the order you want to use them.
It is not currently possible to impose a size limit on the images, but I think this functionality will be added soon.
Alex
Reply #73
Thanks Alex!    And thanks for your work on this Project! Now that it is possible to store album art in flac files I'll be using your tool a lot.
- p
Reply #74
I've been wanting to do this as well, but thought it wasn't possible due to the way REACT2 was coded.  Can you explain how you got it to work?  Thanks!
