Topic: Lame 3.97 Alpha 7 Testing Thread (Read 84967 times) previous topic - next topic
abr/cbr: enabled ath adjustement
vbr new: adjustement of scalefactors allocation
vbr old from 9 to 4: adjustements.
Regarding vbr, I'd be interested by preset medium results compared to previous versions. If results are positives, I'll perhaps apply the same settings to preset standard.
Results from 3.97a6:
http://www.hydrogenaudio.org/forums/index....showtopic=30631
edit: -q1 and -q0 should now work properly
The changes sound interesting...
Too bad I will we working the whole weekend and I am away from my computer and Sennheisers
Hope that Guruboolez has some time
I'm the one in the picture, sitting on a giant cabbage in Mexico, circa 1978.
Reseñas de Rock en Español: www.estadogeneral.com
By the way, it is not at Rarewares...
Yes, is there a link to 3.97 a7? It is not at rarewares.
[a href="index.php?act=findpost&pid=271272"][{POST_SNAPBACK}][/a]
It is now!!!!  Forgive me for having a life away from HA and Rarewares, I was away overnight!!!
@john33:
Thank you, john33, for all your innovations, hard work, and overall contributions to the audio community.  You are very much appreciated.
Regards,
Madrigal
You did not get the memo? You are not allowed a life. Only devotion to digital audio.
[a href="index.php?act=findpost&pid=271409"][{POST_SNAPBACK}][/a]
Forgive me, Master. How am I to be punished????
[a href="index.php?act=findpost&pid=271417"][{POST_SNAPBACK}][/a]
20 lashes with a wet noodle. :B
I'd better not comment. You guys amaze me...
Does 3.97 --decode recognize and process replaygain information if available ?
Since my brother has better ears than me, I let him do an ABX test of lame 3.96.1 versus lame 3.97a7 with:  --preset medium --vbr-new. Personally I've tried and tried and never ever could distinguish both files from original.
The sample I used is from the cd : Judas Priest - Turbo Lover, track 6: Out in the cold. I chose this sample because the recording is not too loud (replaygain -3db) and quite a lot instruments occur at the same time. Although he initially chose the wav file as the mp3, he was able to ABX the difference (p = 10/13 = 0.046). That is for lame 3.97a7. He wasn't able to abx the 3.96.1 one though. Still he gave the latest alpha a 4.5 out of 5. In fact he was quite impressed that mp3 could sound so well  .
Now the strange thing is that the 3.96.1 encode was at much less bitrate than the 3.97a7 one. The 3.97a6 file was 128kbit/s (vbr) and the 3.97a7 file was 154 kbps. I find this difference to be significant. Of course this is only based on one track, but I found the bitrate 'inflation' to be quite constant for several tracks I tried. I guess everybody was hoping for improvement, sorry for reporting the bad news..
A secure audio ripper for linux: code.google.com/p/rubyripper
I would advise you to use either "--preset fast medium" or "-V4 --vbr-new" but not "--preset medium --vbr-new".
--preset are applying their internal parameters immediately, so "--preset medium" is applying the parameters for "normal" medium preset. After, you add --vbr-new. On initialisation, the correct parameters for -V4 --vbr-new will not be used as they have already been changed from their default status.
On the other hand, if you use "--preset fast medium", the preset will know that it will be used with vbr-new, and will apply proper parameters.
If you use "--vbr-new -V4" or "-V4 --vbr-new" you will also be fine.
This will probably explain the strange results, I'll see if I can get another test.
Scalefactor fix for vbr-new is nice. I've seen some files shrink by almost half between 397a7 and earlier versions.
[a href="index.php?act=findpost&pid=272308"][{POST_SNAPBACK}][/a]
Gabriel,
proposed V4 gives rather too low bitrates, around 165. How about V3, which is very near to 192?
Regards,
Crzmn
The current V4 (in 3.97a7) is much more usable than the old one in terms of bitrate. Before there was a huge jump between V5 and V4; sometimes V4 used as many bits as the old 3.90.3 APS. Now the bitrate scale is more linear. Switching from -X 3,3 to -X 9,9 was a good move I think...of course, it's too early to comment on quality.
I would like to add one point to the list to test with current alpha:
I am interested in testsamples where "-V2 --vbr-new" is ABX'able to "-V2 --vbr-new -b32"
Wow the alpha7 is producing much smaller files sizes at the -V4 setting I usually encode at. For example I just encoded Nirvana (MTV Unplugged in NY) and the album average bit rate was only 148kbps compared with 170kbps with 3.96.1 using the same -V4 setting.
take a look at EncSpot for a file encoded with Lame 3.97 alpha 7 with --alt-preset standard:
The lowpass filter shows 18600, I thought usually was the filter on 19000
Is this a bug of EncSpot or a new experimental setting?
Will you perhaps use the new lowpass filter frequency in the following stable versions?
greetings memomai
FB2K,APE&LAME
Subj lame vs one_love.wav
foo_abx v1.2 report
foobar2000 v0.8.3
2005/02/13 18:06:33
File A: file://D:\Program Files\foobar2000\one_love.wav
File B: file://D:\Program Files\foobar2000\_ - _.MP3
18:06:33 : Test started.
18:06:53 : 01/01  50.0%
18:07:01 : 02/02  25.0%
18:07:09 : 03/03  12.5%
18:07:20 : 04/04  6.3%
18:07:31 : 05/05  3.1%
18:07:37 : 06/06  1.6%
18:07:44 : 07/07  0.8%
18:07:49 : 08/08  0.4%
18:07:58 : 09/09  0.2%
18:08:03 : 10/10  0.1%
18:08:20 : 11/11  0.0%
18:08:25 : Test finished.
Total: 11/11 (0.0%)
EDIT: I've forgotten to specify lame settings: -V2 --vbr-new
please, make the sample available somewhere.
What exactly did you test here? Is it a -V2 --vbr-new against -V2 --vbr-new -b32 test??
Thanks, Seymour.
@ beto: I asked him here to abx. you find the sample in that thread too.
@ robert: i found this sample ABX'able very easily with the settings marked above by me (as at low frequency (some wobble bass at first 5 secs) so at high frequency (tone practically masked by first "clap" sound)).
But for example I couldn't find difference (sincerely without hard listening work ) at LAME --alt-preset insane v3.90.3. I tried it just for interest.
