Topic: change directory of playlist items (Read 775 times) previous topic - next topic
I changed the folders where I have stored my audio files. Now the playlists don't work any more.
Is there any way to rename the folders in the playlists, apart from inserting again every single track in the playlist?
My playlists are in fpl format. Most of the audio files are multi-track flac file.
Convertion of the playlist into m3u cannot be used because m3u seems non able to address the single track in a multi-track file.
Thanks for any help
Re: change directory of playlist items
2tec,
thank you for your suggestion! It solved my problem.
