I have a device has analog and digital input and output . Device is from xmos based xcore named XS1-L2 Multichannel input output.
it has 4 analog input and 4 analog outputs and has digital inputs and outputs too.
So when i install two of drivers they can not work at same time. only one driver works and vice versa..
drivers are installed in foobar2000 but foobar2000 has only output component.
is there any of input component?
or any advice?
foobar2000 can not record audio from record devices. It can only play back audio files or streams.
http://www.saunalahti.fi/~cse/foobar2000/?changes=foo_record (http://www.saunalahti.fi/~cse/foobar2000/?changes=foo_record) : record audio from default sound card input
Whoops
