Topic: library_meta_autocomplete not working (Read 422 times) previous topic - next topic
Arash here, I'm trying to upgrade TagBox to use the new SDK and be foobar2000 v2 ready. After tweaking things everything seems to be working, except this piece of code:
pfc::com_ptr_t<IUnknown> src;
static_api_ptr_t<library_meta_autocomplete> lac;
const char* fieldId = field.id.c_str();
if(lac->get_value_list(fieldId, src)) {
CComPtr<IEnumString> e;
if( src->QueryInterface(__uuidof(IEnumString), (void**)&e) == S_OK ) {
static const size_t blockSize = 100;
LPOLESTR s[blockSize];
ULONG cnt;
do {
e->Next(blockSize, s, &cnt);
for(size_t j = 0; j < cnt; ++j) {
l.push_back(s[j]);
} while(cnt == blockSize);
lac->get_value_list() always returns false no matter what fieldId is. tried library_meta_autocomplete_v2, lac->get_value_list_async() returns true but cnt is always zero. This worked without a problem with the older sdk, an I doing something wrong or is this a bug?
I'm using SDK-2022-08-10
Thanks in advance
