Topic: Joan Osborne One of Us Troublemaker (Read 4495 times) previous topic - next topic
Run this through FAAC 1.23.5.  Hear the pain.  Zipped for your protection.  17 second cut.
well..as i remmeber FAAC isnt really developed anymore.
so ther is really no point in using it when there are encoders consider better. (nero & itunes)
Sven Bent - Denmark
Which world?  faac is used as the backend to many frontends, and came in I think middle-of-the-pack, behind itunes and nero in the very recent aac listening tests, ahead of compaact and realaudio.  Where you been?
What do you exactly mean by faac 1.23.5? -q 100? -q 500? What is the problem?
sven_Bent> faac is still in development. No? Development seems to be slow, but not really stopped.
libfaac version 1.23.5 (Dec 17 2003)
Quantization quality: 100
Bandwidth: 16000 Hz
Object type: Low Complexity(MPEG-2) + M/S
Encoding trouble_maker_One_of_Us.wav to x128.aac
  frame          | elapsed/estim | play/CPU | ETA
  733/733  (100%)|    1.4/1.4    |  12.105 | 0.0
Actual bitrate is 118 kbps.  Doing -a 48 (gives 96 kbps) it's even worse.  There is not a lot going on in this sample.  -ns doesn't solve it at 96 but does take most of the bad stuff out.
"Listening" forum, aac tests, was the original location.
A fine example of a TEST SAMPLE!  Don't fret if you can a not a use it.
P.S.  Forum admin(s).  The JohnV? "samples" page at the top of many forums has a dead link.  I looked around a lot for .aac files.  Came up for air after a while with nothing in my hand.
Faac was in the middle yes but still clearly behind NERO/Itunes
i just though Menno once wrote that he did not relly develope FAAC but rather FAAD. He had left the encoding developing to Ivan with the psytell encoder.
Sven Bent - Denmark
Here's a FAAC killer, I can ABX this sample vs. FAAC 1.23.5 <Mar  4 2004> -q 500. Perhaps I'm doing something wrong with FAAC?
also, tried it against NeroAACEnc 2.6.2.0 -audiophile and found that artifacts are introduced in the left channel
