Topic: Toaster for Fb2k (Read 318711 times) previous topic - next topic
Toaster for Fb2k
Reply #150
Thx shaneh for this very nice component.
Would it be possible to enable/disable it via a keyboard shortcut? The "show toast" feature isn't exactly what I thinking of, as it is a one shot action. A shortcut to "enable toasts" would be really useful for people like me who only use the toaster when remote controlling foobar (which means, who need to activate/desactivate the toaster quite often). What's your opinion?
Toaster for Fb2k
Reply #151
What do you use to remote control FB?
Toaster for Fb2k
Reply #152
[a href="index.php?act=findpost&pid=299468"][{POST_SNAPBACK}][/a]
I'm using Girder combined with the ATI remote control driver. Girder is based on keyboard shortcuts an works perfect with most of foobar's features.
Toaster for Fb2k
Reply #153
Feature request maybe?
Something like a "music video mode" where it shows the toaster for 7 seconds after the song starts, and comes back for the last 7 seconds of the song.
Toaster for Fb2k
Reply #154
[a href="index.php?act=findpost&pid=299471"][{POST_SNAPBACK}][/a]
How do you control volume changes?
I'd like to control the main volume and for now I'using "volume toolbar up" and "down" but I have some problem.
I've been able to program most of FB feature through keyboard shorcuts but I can't see the volume change more than one bit for each press even if I see girder gets a stream of signals.
I read also some posts from the girder forum but I still don't know how to use girder's volume command.
Do you mind give some help, please?
Toaster for Fb2k
Reply #155
New user.
Ok. All I want to know is, 'how do I install toaster to use the 'now playing' feature in MSN messenger 7 with Foobar2000'?
I have no idea?! please tell me how to do it, i've been looking for ages.
Sincere thanks,
zen
Toaster for Fb2k
Reply #156
New user.
Sincere thanks,
zen
[a href="index.php?act=findpost&pid=303887"][{POST_SNAPBACK}][/a]
Under the 'Extra' tab when you go to 'Configure Toaster'.
The nowplaying seems to work randomly, mine suddenly stopped working.
Any help?
Toaster for Fb2k
Reply #157
I can't even figure out how to 'install' toaster.
It keeps coming up with 'install in winamp folder', when that isn't even on my computer?
Toaster for Fb2k
Reply #158
Use the foo_toaster.release.rar file and extract it into the foobar 2000 component folder. You are using the winamp version. Don't use that.
The foobar2000 version is available from http://www.myplugins.info
Toaster for Fb2k
Reply #159
I can send you some info via PM if you want, I don't want to pollute this Toaster thread with stuff that's nothing to do with it. It seems I'm not gonna get any answer to my question/request anyway.
Toaster for Fb2k
Reply #160
Great plugin. I was wondering if you can make an option to disable 'always on top'? I think it will be quite useful for some. Thanks!
Toaster for Fb2k
Reply #161
Very minimal formatting, but it stays there  forever. Very helpful. thanks for the great plugin.
Toaster for Fb2k
Reply #162
Is there a possibility to show toaster's display only when foobar is minimized to the tray?
That would be very fine (not to have the information on screen twice).
Toaster for Fb2k
Reply #163
hi, somebody can help me, where i can configuration toaster in foobar?
Toaster for Fb2k
Reply #164
[a href="index.php?act=findpost&pid=309042"][{POST_SNAPBACK}][/a]
Menu -> Components -> Toaster -> Configure Toaster
Toaster for Fb2k
Reply #165
[a href="index.php?act=findpost&pid=309067"][{POST_SNAPBACK}][/a]
but i dont have it  this is a problem. i have fb2k 0.83 and i see red note with song (in center) but i dont have menu to configuration ;<
Toaster for Fb2k
Reply #166
I think someone else had this problem. Try resetting your menu config eg. in preferences go to Core>Main menu items>Reset menu state.
Toaster for Fb2k
Reply #167
[a href="index.php?act=findpost&pid=309182"][{POST_SNAPBACK}][/a]
nop
Toaster for Fb2k
Reply #168
where/how to config toaster of fb2k version ?
Toaster for Fb2k
Reply #169
It's been written 4 posts above yours.
Toaster for Fb2k
Reply #170
[a href="index.php?act=findpost&pid=309453"][{POST_SNAPBACK}][/a]
ya...I know this location, but I didn't find Toaster under menu->components
and I followed krazy method to reset menu state but no help
I'm using fb2k 0.8.3 and toaster 0.16
Toaster for Fb2k
Reply #171
[a href="index.php?act=findpost&pid=309454"][{POST_SNAPBACK}][/a]
i have the same problem
Toaster for Fb2k
Reply #172
Guys, try above method.
It should work I think.
Or, try following steps:
1. First, make sure foobar is not running. Remove toaster plugin from foobar component direcotry.
2. Start foobar and reset the menu as indicated above.
    Menu->preferences-> Core-> Main menu items, click on "Reset menu state" button on bottom right coner.
3. Close foobar program.
4. Reinstall toaster plugin in foobar component directory.
5. Restart foobar program.
Got the menu now?
Toaster for Fb2k
Reply #173
thx it works!
but i am stupid, because u searched TOASTER i PREF/COMP (all the time i dont see) but i have i COMP. on top line with pref, playback, playlist :D
btw have i can make that toaster show my any jpg file as cover, because i dont have folder.jpg eg. i have ASDC43.jpg  in toaster for winamp that was *.jpg but i fb2k?
Toaster for Fb2k
Reply #174
[a href="index.php?act=findpost&pid=309753"][{POST_SNAPBACK}][/a]
Yes, *.jpg only works on the build on winamp. The author did promised to update this feature on next release of the toaster for foobar. I've been waiting for it for months...
Hope the author will continue with the plugin and release a new version soon.
