Topic: foo_rating100 - ratings out of 100 (Read 1036 times) previous topic - next topic
This component stores ratings on a scale of 0-100 inside the foobar2000 database alongside a timestamp of when the rating was last changed.  (It's really not much more than a modification of the SDK sample component.)  I made this a long time ago because foo_playcount only stores ratings on a scale of 1-5 (which isn't granular enough for the way I use my library) and because I also want the rating timestamp to be available for sorting/searching.
The metadb_io_edit_callback hook is implemented, and ratings are binded to tags as follows:
$lower(%artist%$tab()%album%$tab()$if(%discnumber%,%discnumber%,1).%tracknumber%$tab()%title%)
This adds the following 2 fields:
%foo_rating100% - The rating, which is either <none> (initial value) or a number between 0 and 100
%foo_rating100_timestamp% - The timestamp that the rating was last touched.
This adds the following 26 context menu commands inside a "Rating/100" folder, intended to be binded to keyboard shorcuts:
1. 21 commands for "Rate n", where n is every multiple of 5 from 0 to 100
2. 2 commands for +/-1 and 2 commands for +/-5
3. 1 command for "Erase Rating" (where <none> is separate from a rating of 0)
This also adds a main menu command for dumping the ratings database as tuples of the database hash, the rating, the timestamp, and the matching filepath(s).  (However, this is of limited use currently, as there is no import function.)
If there is interest in this component, I'd like to find someone more familiar with the foobar2000 component SDK to maintain it.  (Or better yet, convince Peter to put these features directly into foo_playcount.)
Re: foo_rating100 - ratings out of 100
Visual rating title formatting (also sortable):
$if(%foo_rating100%,$repeat(█,$div(%foo_rating100%,20))$select($mod($mul($div(%foo_rating100%,5),5),4),▎,▌,▊)$ifgreater($mod(%foo_rating100%,5),0,▏,)$ifgreater(%foo_rating100%,4,,▏) %foo_rating100%,)
This makes use of block characters which are not rendered correctly in all contexts.  You will want to use a font that is not monospaced to join them together.  It works for me in foobar2000 as a search column / playlist view column.
