Topic: Columns UI appearance (Read 3297057 times) previous topic - next topic
Reply #475
the starting point in Kameleon is to draw the background image (wallpaper, cover or artist photo) then i place an elplaylist panel in the panel stack splitter (the main one that contain the bg image) with pseudo-transparency turned on (right-click on elp -> settings ...)
so, first : create a new columnsUI layout, add a splitter to be the base-panel (a panel stack splitter = the main container)
then add under it (in CUI panel tree viewport) all other panel, especially those whci support transparency like elplaylist as said above.
then, you have to code the display of the bg image, using titleformat script in the settings of the main PSS (Right-click on the PSS -> Splitter Settings ... -> 'Per Track' section)
2 functions available to display images : $imageabs(...) or $drawimage(...) => see the text file that come with the panel stack splitter dll for the syntax).
after, all is imagination and titleformatting to manipulate panels, images, buttons, variables ... etc
HTH.
bye
Thanks for your quick reply. Although it still looks a bit complicated for me, I will try and do some experimenting.
Reply #477
[a href="http://xs.to/xs.php?h=xs137&d=09112&f=t779.jpg" target="_blank"]
new config, part of my VPR suite
Reply #478
My very basic configuration. Would like to use PSS as well, but still have to learn and read about it.
Reply #479
I've been a Default UI user for a long time now since it became a lot easier to use and was more customizable. But then you don't have too many UI elements to play with yet so I went back to Columns UI and boy was that nice.
I'm still working on the EL Playlist configuration. I don't seem to find any English documentation on the syntax to use.
As you can see I made a drawing application in WSH Panel which is one of the best components out here now. It does not use title formatting syntax but JavaScript which makes it so much more powerful and also a lot easier to use (JavaScript is a real script language, title formatting is not).
If you want the JavaScript code grab it here.
Again if anyone wants to teach me how EL Playlist works or lead me in the right direction I would be eternally grateful.
Reply #480
This is my custom CUI-theme (version 1.1 )
[a href="http://img.photobucket.com/albums/v234/peldi/Musik/fookhgukj.png" target="_blank"]
Reply #481
Its not as stylish as many other themes here, but its MINE and its ideal for my needs
Nice theme, if you don't mind me asking what font are you using there.
Reply #482
Thank you!
The fonts are:
Square721 BT for title, album and artist on the top and for the tabs
Segoe UI for the playlist items
Arial Unicode MS for everything else
PS: I'm sorry i dont know if Square 721 is freeware...it was delivered by any program on my PC.
Reply #483
"MINE", this is the _most_ important thing imo. No matter how customizable a theme is, it will never fill your needs exactly : )
Could you please share your theme? I'd like to steal some things : d
edit: I really like the simplicity you got there, no flashy crap
Reply #484
http://img.photobucket.com/albums/v234/pel...k/fookhgukj.png
You're absolutely right!
Sure. You can download my FCL here:
http://peld.pe.ohost.de/foobar_stuff/theme.fcl
(Dont know, whether your current themes are overwritten by importing?! Better you export them first.)
Have fun stealing my ideas!
If you need something else, please ask!
Im glad you like it
Reply #485
Peld, thanks =3
Reply #486
I recreated my Columns UI layout from scratch this week and made some updates. The layout is simple but offers great usability and designed to look native on Windows.
Album view:
Single files view:
You can get the fcl file of this layout on this link.
"I never thought I'd see this much candy in one mission!"
Reply #487
Im glad you like it
Great work Peld!
Tried importing it though and the buttons (Start,Stop,Skip etc) are missing. It can't load the images. Tried moving the png's elsewhere and pointing to the new directory but still no luck..
Everything else seems to work fine!
Any ideas?
Reply #488
Great work Peld!
Any ideas?
I dont really know why this issue occurs but i uploaded the FCB files of the three button panels for you.
Maybe it works when you import them in the properties of your button panels (see screenshot)
http://peld.pe.ohost.de/foobar_stuff/buttons/
controls.fcb - the controls on the top (start, stop...)
rating_top.fcb - the other buttons right from the controls (rating etc.)
rating_bottom - the buttons in the left bottom corner
Also you can find all the PNG files in the gfx folder.
Reply #489
fooStriped w/ PSS + elPlaylist
link to original
Reply #492
will share it when i'll have more time...
when i'm on vista and use Segoe UI font, $char(9733) shows a star. when i use Segoe UI on xp, i get an odd squared symbol with a question mark inside. is there a way to display stars from Segoe UI font on xp like on vista?
Reply #493
Did you try to just use the symbols themselves instead of using $char(xx)?
Copy and paste!
Reply #494
no, it doesn't work. all i get is this:
maybe the segoe ui font i've got is not complete. or it can't be done with my charset (but on vista it works with the same charset).
have you got xp?
+ i don't even see the star on the character map. does anyone see it on their character map?
the only workaround i've found so far is to use wingdings font, but the spacing between the stars much bigger than on segoe ui and it doesn't look as good.
Reply #495
@Jeremija
You can't use Segoe UI on XP to display stars.
Segoe UI hasn't these characters in its charmap, similar to Tahoma on XP it ony "leans" the characters from other fonts on vista since it is the standard font.
To get stars on vista and xp you should try with Tahoma (although there may be problems displaying the stars on vista...) or Arial Unicode MS.
Many east-asian fonts have this chars too.
Since you use ELPlaylist the best solution would be to use images for the stars.
Reply #496
thank you for your reply!
i ended up using wingdings in my config... it's not so bad after all!
@lokioki & acedriver:
yes it should work with the latest version (i have 0.9.6.1)
here is the download link:
http://compater.deviantart.com/art/fooStri...ns-UI-116301216
Reply #497
Awsome theme mate!
but i have a problem:
- and second thing is that i don't have the theme's minimize and close button and top bar some how.
here is a screen:
Reply #498
That's done by the visual style that he is using, it is Lassekongo83's FooStriped VS.
