HydrogenAudio
Hosted Forums => foobar2000 => General - (fb2k) => Topic started by: timalina on 2016-01-05 11:01:35
Title: Filtering Duplicate FLACs Using MD5 Hash
Post by: timalina on 2016-01-05 11:01:35
I am trying to identify duplicate FLAC files/albums from my collection using the MD5 hash in the header.
I would like to do this not through the library (I haven’t set one up) but using a playlist (.fpl) I have created of all tracks with the tracknumber tag value “1”.
What I want to achieve is a filter that contains only files and every file where two or more contain identical MD5 hash values [$info(md5)].
I’m not good technically so would really appreciate if someone could talk me through exactly what I would need to do to filter my playlist accordingly. I’m happy to explain why I’d like to do it in the way I’ve described if it is not obvious.
Post by: timalina on 2016-01-05 13:44:34
Is it even possible  to do what I'm asking?
Post by: marc2003 on 2016-01-05 13:55:48
It's not possible with a playlist. You need to enable your media library and then install foo_facets. Configure with it with a custom column containing [$info(md5)]. Then right click the column header to enable statistics>Items.. You'll want to reverse sort this so anything with more than one match appears first. Then in the next pane to the right, you can configure it with a custom %path% column so you can see the location of your duplicate files.
I don't have any duplicate files but I made a copy just to show it as an example:
(http://i.imgur.com/KZmwOd4.png)
Post by: timalina on 2016-01-05 14:29:11
Thanks very much - that is very helpful. I'll give this a go but I don't think that my computer can handle my entire media library as it is extremely large, hence why I was trying the playlist route with only the first tracks included. If that fails, I'll have to go through the playlist manually.
Title: Re: Filtering Duplicate FLACs Using MD5 Hash
Post by: timalina on 2016-01-18 13:35:25
I just wanted to thank you again for your help. That solution worked perfectly and highlighted loads of bit for bit identical files that needed flushing out.
Also, I thought I would correct you on one small point which is that you can use foo_facets on a playlist although in the event, I was surprised to find my server coped with the entire collection, so happily I now have a workable and dynamic music library.
Post by: marc2003 on 2016-01-18 20:53:28
Yes you are right. I had been aware of that in the past but I completely forgot.
Post by: VivinCels on 2022-05-25 16:22:04
I just create column in playlist, in pattern I set $info(md5)
Spoiler (click to show/hide)
I have another question. Is it possible to automatically remove lines from the playlist that do not have duplicates with the same values ​ ​ in a specific column? In this case, I would like only groups of duplicates to remain in the playlist. Like this:
Post by: SimBun on 2022-05-25 20:02:35
That's what facets as described above will give you.
If it were me, I'd be using foo_sqlite (https://www.foobar2000.org/components/view/foo_sqlite). Using this you can run sql against your media library/playlist to identify duplicates (based on md5) and then push the resulting tracks out to a playlist.
drop table if exists Playlist_Updatable;
create virtual table Playlist_Updatable USING MetaDB_Module(no_multivalue_split,playlist);
insert into Playlist_Updatable (path, playlist_name)
  select path,
         'Duplicate Tracks'
  from Playlist
  where playlist_index = active_playlist()
            and md5 in (select md5
                  from Playlist
                  group by md5
                  having count(*)>1
drop table Playlist_Updatable;
If you want to run it against your entire media library, just use
  select path,
         'Duplicate Tracks'
  from mediaLibrary
  where md5 in (select md5
                  from mediaLibrary
                  group by md5
                  having count(*)>1
Post by: fbuser on 2022-05-25 21:50:50
With the latest version of foo_sqlite you should omit
at the beginning and
at the end of your scripts and use PlaylistUpdatable instead of Playlist_Updatable. PlaylistUpdatable is now automatically created.
Post by: VivinCels on 2022-05-26 02:49:45
Thank you. I tried execute both commands, but SQLite console says "SQLite Error:(1) no such column: md5"
Post by: SimBun on 2022-05-26 07:20:23
foo_sqlite comes with a bunch of default tags/columns set up by default; to add additional tags that exist in your media library go to 'File > Preferences > Media Library > SQLite viewer' and select 'MediaLibrary table', then click 'Add defaults' and 'Apply'. Does this add md5 to the list of columns available? Repeat for 'Playlist table'.
If that doesn't add it, can you let me know which version of foobar you're using, and if you have foobar configured with a media library of if you're just adding files to foobar via playlists?
I'm out for a few hours now, but will take a look when I'm back later if that doesn't work.
Post by: VivinCels on 2022-05-26 08:41:52
Yes, now there are tags in the MediaLibrary table, including md5. I executed this script:
  select path,
         'Duplicate Tracks'
  from mediaLibrary
                  from mediaLibrary
                  group by md5
                  having count(*)>1
Now I understand, that SQLite takes the list of tracks from medialibrary, I configured it too, it has status monitoring folders wich have duplicates.
Result can see:
Thank you very much for help, plugin and scripts  :)
P.S. I also tried execute this script:
  select path,
         'Duplicate Tracks'
  from Playlist
                  from Playlist
                  group by md5
                  having count(*)>1
But it still says "no such column: md5":
Post by: SimBun on 2022-05-26 11:07:41
Did you also 'Add defaults' to the 'Playlist table' too?
Post by: VivinCels on 2022-05-26 12:21:04
No. But now yes and now second script works too
Post by: SimBun on 2022-05-26 12:42:25
Glad you got it sorted.
It's a great plugin, and is the only tool I know of that enables you to perform queries across groups of tracks e.g. at the album level.
I use it a lot for QA purposes, things like checking that there's only one artistsort per artist, but have also used it for updating tags. There was a guy on the MinimServer forum that wanted to create a tag that contained the album duration so he could show it in his control point, and this plugin made that trivial. I also added DISCTOTAL to my library as I hadn't included it originally but found a use for it when I was performing conversions.
Post by: SimBun on 2022-05-26 12:49:15
In my recent scripts I had moved over to using PlaylistUpdatable, but I hadn't realised it was automatically available so that simplifies the scripts a bit.
Thanks again for the plugin.
Post by: VivinCels on 2022-07-22 11:47:13
Hello again. Is it possible to set a term so that duplicates are allocated (marked) only in a certain directory and its subdirectories? For example, there are already files in different folders and on different disks and you need to compare them with files that are in a certain directory and its subdirectories, in this case in the F :\! Labels. After finding duplicates need only to mark them or to delete to the recycle. Need a script to select duplicate in a ready-made list with duplicates found
(https://i.postimg.cc/7ZpFwsyY/2022-06-16-1056082.png)
Post by: SimBun on 2022-07-22 15:26:52
I'm not entirely sure I understand.
If you're just trying to run the code against a subset of your collection then the easiest way to do that is just to filter the active playlist rather than change the sql.
Or are you asking instead to compare directories, so find files from Path A that also exist in path B?
Post by: VivinCels on 2022-07-22 16:53:43
There is already a ready list of duplicates. I need just select all duplicates that are located in a specific folder and its subfolders in order to remove them to the recycle bin. Like this:
(https://i.postimg.cc/FRd41CVn/2022-07-22-205851.png)
Post by: SimBun on 2022-07-22 18:04:01
Given it's a playlist can't you just filter it by the path?
I use facets, and if I type 'H:\' into the filter bar it'll automatically select everything that resides under that path, at which point I can delete them.
You could change the query so it only kept one, but how would it know which one to keep, what if there were duplicates under T:\ AND under H:\? Alternatively, if you just wanted to find files in H:\ that were already in T:\ then that's possible, but that's what I suggested before.
