Topic: Wavpack lossy - Noise shaping off (v5.1) (Read 8357 times) previous topic - next topic
Hi everyone,
I'm planning to convert my whole audio CD archive (200 CD) to wavpack lossy around 350k.
As I read here long time ago, this bitrate should provide perfect quality for "normal" music (also for single transcode to lossy for portable use), but I also read that it is realiable to use -s0 switch (noise shaping off) on higher bitrate like 350k+.
I think that shadowking (maybe you will read this ;)) mentioned before that  -s0 switch is more stable than default setting on some samples.
I was wondering is this still the case with new v5.1 and is setting like -b350hx enough for single transcoding to opus/vorbis around 96k for "normal" music?
Best regards,
Re: Wavpack lossy - Noise shaping off (v5.1)
in wavpack-lossy keys -h, -hh increase size, use -f; x=from 1 to 6, 1 by default; imho, only mp3 does not enough 350k for transparency.
why wavpack? maybe musepack -standart will be enough?
Hi, Shinichi
My suggested settings:
Wavpack v4.41 or below : Use -S0.
Wavpack v4.50 to present: Use defaults (dynamic noise shaping is enabled for sample rate <96khz )
Suggested bitrates  / switches for archive without .wvc:
 -b350..400 (-h -x levels 4 .. 6)
Suggestions: below settings are based on quality as the most important criteria and doesn't sacrifice it . They are different to the -b384x3 suggestion in the wavpack manual which is expected to be used with the correction files.
Encoding parameters without -c / .wvc: ( Use nothing less - do not take any shortcuts)
-b400hx6 -- slower encode extra headroom
-b384hx4 -- faster encode and slightly more economical
Wavpack works great with the correction files 256..320k . I use 265k (-b3)  for portable and on the PC the .wvc makes playback lossless. It can also work well 'near-lossless' without the correction files at bitrate around 400k or more -- Say you are fine with 400k files on all devices etc or transcode them to lossy of choice.
Hi shadowking, thanks a lot!
hx4-6 are really slow and I would like to avoid it if possible.
What if I go slightly higher in bitrate? Let's say something like -b450hx1-3 or similar?
Do I still need x4-6 in 450k range?
My goal is to create two quality archives which combined together should be around half size of a lossless file (~900-1000k). ;)
For desktop/hi-fi will be high bitrate wavpack lossy (350-400k) and 96-112k opus/vorbis for portable use. ;)
I'm aiming at maximum efficiency while reataining high quality lossy + portable archive, if possible.
than...
Wavpack works great with the correction files 256..320k . I use 265k (-b3)  for portable and on the PC the .wvc makes playback lossless.[...]
-hhb320cx6/-fb256c
You could try -b450x4 as that still benefits from -x4 while being faster.  -hx3 is an alternative a bit faster to encode ..  I still have to consider this no longer a quality 1st approach , but acceptable in the context of speed and the bitrate inflation. The effect if any should be minimal or not audiable.
than...
-hhb320cx6/-fb256c
Thanks, this is also an option for consideration but I think that I will go lower with bitrate for both archives. ;)
If x4 setting is better, even in normal mode, than hx3, I will use it. ;)
On average, hx3 compresses slightly better and that should translate to a bit less noise in lossy (though it very close to -x4).  There are some rare cases where the favour goes to -x4 (artificial music etc)
After a lot of thinking about your suggestions, I've decided to go with a setting: -b450hx4. It's slow but I think it's worth it.
I was thinking that I'm going to encode my music archive once and keep it forever so it should be done right. :)
What could be worst case scenario with this setting if I encounter hard-to-encode /difficult song?
Good choice. The theoretical difference in normal music is zero IMO . In artificial sample like very HF noise / sines etc, there is a very slight possibility of a tiny change in background noise. But taking into account the bitrate and the hx4 + DN Shaping, probably close to zero on that too. You need amplify a HF noise by a magnitude, and IMO that is a risk for physical and equipment damage.
Also, On Windows you can use -l switch to enable low priority the the wavpack.exe thread, If your going use your PC while encoding. I think even -hx4 is not that slow on a modern cpu- its twice as fast as hx6.
From the manual:
 -l = run at low priority (for smoother multitasking)
This option can be used (in Windows only) to force WavPack to run at a low priority and is handy for doing large WavPack batch conversions in the background.
Thanks a lot!
Didn't know about -l switch. It will come in handy.
I also done a few CD conversions using this setting today (-b450hx4). It's not that slow. I'm getting 40x realtime on average in foobar2000. So, about 2 minutes per cd album.
I thought it will be far worse. :)
As for those rare cases when a difficult sample may show up, this tiny noise difference will probably go unnoticed in normal listening. All things considered, pretty good IMO.
And still half size of a lossless file. :)
Thanks again for suggestions. That helped a lot.
@shadowking
I have one more question:
If I want faster encode while still retaining relatively high quality and smaller file size, what setting would be good compromise between speed and quality?
I was thinking to use something like: -b350hx.
Is that good enough for normal music? I don't want to go any lower that that. ;)
I'd consider hx2 , much faster than hx3 not much slower than hx
Ok. Thanks a lot. :)
