Topic: Foo_msn (Read 237140 times) previous topic - next topic
Foo_msn
Reply #52
Any chance of an update to correctly show tag info for online radio streams?
Foo_msn
Reply #53
Odd in the latest WLM though, is that they seem to have switched around artist ({0}) and title ({1}) in the formatting string?
It seems that way to me as well. I'm using WLM build 689.
Foo_msn
Reply #54
I just added a menu item to let user select if show now playing to the msn status bar. (View->Display now playing)
And fixed the parameter order defect. I tested it on foorbar 0.9.3 . It works fine:)
This is the plugin: [attachment=2530:attachment]
the modified source code: [attachment=2531:attachment]
Foo_msn
Reply #55
thanks for this plugin!
it also works with miranda in conjunction with the ListeningTo plugin.  Keep up the good work.
Foo_msn
Reply #56
I'm using 812... and it seems to cut off the name of the song? Artist shows up though
EDIT: Unchecking WLM mode fixes it.
Foo_msn
Reply #57
hi, could somebody please tell me what i do with the sourcecode? I have no idea
Foo_msn
Reply #58
Yeah, i'm only listining to radio streams so an (little) fix it would be very nice
Foo_msn
Reply #59
Thanks. It works fine.
Foo_msn
Reply #60
Hi, i'm using foobar 0.9.4 and MSN live 8.1 version.
Is there a way to make it working? I tried different plugins but no way to have the song displayed
Help!
Foo_msn
Reply #61
Help!
I had the flag of "display the listening music" OFF in MSN
Disregard...
Foo_msn
Reply #63
This is indeed a fix I'd really like to see in the extension. It would be great if you could do it !
any progress here? i would appreciate this feature as well!
Foo_msn
Reply #64
the plugin works with msn 8.1.0178.00 and foobar 2000 0.9.4.2
Foo_msn
Reply #66
I downloaded a different dll from http://stephan.kochen.nl/proj/foobar2000.html#msn
http://stephan.kochen.nl/proj/foo_msnalt/foo_msnalt.dll
Should I use the aforementioned plugin (it works with MSN v8.1.0178.00 / Foobar 2000 v0.9.4.3) or the one uploaded here?
Also, How do I get the Artist tag to appear BEFORE the song title?
edit: Never mind, I just figured it out...
Foobar Preferences => Display => MSN Now Playing  'MSN format' {1} - {0}, instead of {0} - {1}
Foo_msn
Reply #67
It works fine with xp, but i can only use "generic fields" to show on msn. Things like "%list_total%" doesn't seem to work. Is there a way to get other fields in your msn personal message?
Foo_msn
Reply #68
I have modified foo_msnalt so now it updates the information of internet radio streams as it changes.
Tested with foobar 0.9.4.3 and MSN Messenger 8.1.0178.00 .
Source included in the zip.
Foo_msn
Reply #69
Wow thanks m8      the only problem is that i'm using Arch Linux on the moment
Foo_msn
Reply #70
Thanks RayMcCoy! Just what I was after!
Foo_msn
Reply #71
it works with foobar 0.9.4.4 and WLM beta 8.5 build 1238.
Foo_msn
Reply #72
does this work for anyone? i got the latest 8.5.1302.1018, and it doesn't anymore :/
Foo_msn
Reply #73
It's working for me. I'm using foo_msnalt 2.4.
Foo_msn
Reply #74
Same for me, I just updated live messenger today and it stopped working.  Using foo_msnalt 2.4 :/
Why oh why can't MS just stop re-inventing the wheel? lol
z.
