Topic: Feature Request: Do not call Explorer.exe directly (Read 12596 times) previous topic - next topic
I use litestep for my shell and every time Fb2k opens a folder, it opens explorer as my shell before it opens the folder view
My request is to make the command to open a folder configurable
Personally I never use Windows Explorer, since it's heavy and uncomfortable to my taste. A configurable file explorer option seems like a great idea.
u can use foo_run.dll for this, I used to use it with total commander. Can be used with any program which can use parameters.
I am not looking for add functionality, I want to change the native functionality
How do you propose it handle folders? I assume it already uses the native file associations by calling ShellExecute on them.
I could be wrong, but I believe it calls explorer.exe directly
Error Dialog
Process properties showing command line
When I open a run dialog and type 'F:\' it opens it without opening the explorer shell
I get the same result in VBScript if I create a Shell Object and use .Run "F:\"
maybe its doing something like this
where it highlights the file that you're opening?  from the way that thread reads, explorer is the only way to select the file in the folder.
My mistake, that's exactly what it's doing.
I second this request.
I'm using explorer, but the /e switch opens the folder with the treeview, which I never use. It's quite annoying to have to close it each time.
As mentioned use foo_run which allows you to set up your own "Open Containing folder" item, then just remove the native one.
Until the core functionality changes this is your only option I'm afraid.
The easy solution is to put the executable path foobar2000 uses for this as an advanced option. Make the string configurable.
PS! And also to expand all tree items on the advanced configuration page by default.
It seems to like to cause second instances of explorer.exe to run which drives me nuts, as well as not re-using existing windows when they are the same folder.
Doesn't even seem to be a fully qualified path, you can put any executable named explorer.exe in your foobar2000 folder with funny results..
What's wrong with SHOpenFolderAndSelectItems?
another vote for this to be configurable, it could do multiple thingies as well, example:
- display in right pane of active total commander window
- paste to clipboard
Wasn't available on some of target operating systems at the time relevant code was written. Thanks for the tip, I'll use this function instead.
Thank you
