Topic: [PUI]Minimized Foobar - no Title refresh on switch (Read 2045 times) previous topic - next topic
Hi, I'm using quite an old version of foobar (0.9.5.2) because I use an old Skin (Uru-Foo V2) which requires PanelsUI.
The problem i came across, now under Win7 I dont use the Minimize-to-tray function anymore, I just leave it minimized in the taskbar.
So when I skip to the next song, the title in the taskbar stays the same as the previous title.
I assume foobar just doesnt refresh the window title in minimized mode!?
Is there any known workarround, or does this only work with newer versions?
Thanks for any help, phil.
We no longer answer PanelsUI questions, in this forum.
But I can tell you that anything related to the taskbar or notification area or window is the fault of the active user interface component.
Thread Closed
elevatorladylevitateme
