Topic: Why 24bit/48kHz/96kHz/ (Read 401905 times) previous topic - next topic
Reply #175
Okay, so you're saying that to hear the 1 bit sound, you would end up blasting your ears with everything else.
I agree.
Now let's ask "what bit resolution is necessary" for this quietest sound?  When I say "quiestest sound" I mean the quietest sound on the track of which you can still discern its quality.
If this "quietest sound" were 8 bits, would you be able to tell?  That means that it has %0.4 steps on it.  I would guess that this is probably around the threshold of hearing.
This quietest sound would only have to be 48dB down on the 16 bit recording to render it 8 bit precision.
I don't know the answer to this question, but the limit of perception is definately bigger than 1 bit, so the 96dB figure is strictly an upper limit.
While you are right that the SNR of the quantization noise of a 16 bit signal is 96dB, keep in mind that we're talking about the *quality* of the quietest sound.  So if this quietest sound was at -96dB, then it would have no quality at all because it would be a square wave.
The real question should be "what bit resolution is necessary *FOR THE QUIESTEST SOUND*."  At 16 bits, the quiet sounds are audible, but they don't have the same detail as the louder sounds.
That is a strawman argument and, in fact, is not the question.
Clearly, if you want to encode a signal using only the least significant bit, you will have large amounts of distortion - after all, it's a 1-bit signal. But those signals simply do not exist in real life. The most important reason is that nobody would want to listen to actual music on it - there's no known listening environment, or set of listeners, that can tolerate more than 60db of dynamic range. There is also no popular or classical music with 90db of dynamic range.
I don't think you are able to come up with a valid use case where the quantization noise is actually important, unless you want to cause permanent hearing loss in the listener. If you wanted to record the Space Shuttle taking off, then sure, you'd probably need 24 bits of precision. But that has no bearing on the use of CDs to store actual music, or failing that, sounds that people really want to listen to.
Now check this out.  You can get 24 bit audio from 16 bit CDs - how?  Use ogg vorbis at a very high quality level.  The file now contains *frequency* domain information.  That means that if there is quantization, it will disappear with a decoder running at 24 bit accuracy.
You are confusing "accuracy" with "precision". Look it up. You will never get better than 16 bits of accuracy out of CD, even if you decode to 64-bit floating point, no matter which format you use.
Reply #176
I will definately look up the reference.  Thank you.
But the question of dithering is a side issue.  You can certainly use the LSB of any data stream and modulate it at a higher frequency to emulate a higher precision, provided that you oversample at a sufficient rate.
My main point was that on a 16 bit recording, the softer sounds are not 16 bit precision.  This begs the question of what precision is transparent for these softer sounds.
Please go to a good reference library and read Bart Locanthi Sr's paper on dithering.
Thank you.
Reply #177
jhbretz, your post above is very cryptic... could you take a shot at rewriting that?
edit: oh - I meant the first of the two above here
Reply #178
This quote of mine below intuitively sounds like nonsense, doesn't it?  (Maybe this is why I got "warned")  But hear me out - I was just posting this to see whether anyone was listening.  And someone is!  Very exciting!
Let's say for the purposes of discussion, the "softest sound" on a recording is at -60dB.  On a 16 bit recording, that means that it is only at 6 bit precision.  It has "steps" of 1.5% signal amplitude at the sampling frequency.  Now the act of encoding with vorbis fits this 6 bit signal with the RMS minimum error frequency components.  In doing so, an interpolated signal has been created that doesn't have the 1.5% steps in it.  (CT Fourier transform coeffiecients are discrete but the frequencies themselves are continuous)
The fact that sounds in general are very well correlated means that the interpolated signal is a good fit for what the signal should have been.
Reply #179
Ah... I think I know what you mean by "steps of 1.5%" now. You mean the quantization error has a relative size of 1.5% on a signal of 2^6 amplitude, right?
Well, the bad news is: no Fourier transform is going to give you back the lost information. The error just takes another form in another domain.
Thus, without the transform, the quantized signal is just as good a fit for what it should have been. And since encoding to vorbis does a bit more than just transforming to the frequency domain, the fact is that the original wav is a better fit than the ogg.
If you got a warning, I think it wasn't for this erroneous thought, but rather for claiming you could obviously hear it...
Reply #180
No. Quantization introduces noise. When you decode at 24 bits, you still have got the 16 bits noise introduced by the ADC process. It doesn't disappear. It is encoded and decoded.
The difference between 16 bit and 24 bit is just OBVIOUS.  Especially quiet sounds with some texture, like the echos after a background percussion hit.
Please, provide ABX results.
I just did an informal ABX and was able to discern a 16 bit wav from its vorbis encoded & 24 bit decoded equivalent consistently.  I did another test decoding the vorbis at 16 bit and 24 bits and got the same results.  How should I go about providing these results?
Reply #181
Describe the process you did to create the test, list the sample(s) you used, and post the score from your ABX test.
Reply #182
You'll need to go from informal to formal
* what equipment were you using? (e.g. if you played back the 24bit file on a 16bit device it might sound different due to lack of dithering)
* were the levels the same after the encode/decode cycle? (you can check this in your wav-editor)
* how did you do the blinding (what software)?
* how many rounds did you do (without checking how you were doing!)?
Reply #183
You are, I presume, aware of the absolute threshold of hearing?
I should, I suppose, also point out the fact that the atmosphere, being made of molecules of gasses (N2, O2, CO2, H2O primarily) and atoms of Argon, is discrete in nature, and that "air pressure" is in fact exactly the result of the momentum of the molecules and atoms bouncing off something.
This means that there is a noise level to the atmosphere.  For something the size of an eardrum, it's reasonably close to 6dB SPL, white noise, in the 20Hz to 20kHz range. This is a noise in the system that can not be removed, ever, unless you remove the air from both sides of the eardrum, which I believe may create some difficulties with the listener involved.
Standard understanding of noise-masking-noise shows that if you have noise in a critical band, and you wish to use to to mask some smaller noise, that an SNR of 3 to 4dB is sufficient to mask that noise.
That is what we have when we have quantization noise being masked by the atmosphere (which, by the way, is just SLIGHTLY below the threshold of hearing in the most sensitive ERB), with the quantization noise being at, oh, about 3dB SPL. That puts the peak level from a system operating in the quietest room on earth at 98dB SPL for peak levels.  For much presentation, this is completely sufficient.
Now, if we consider a quiet, normal room, what happens? We have at least 20dB more headroom. So, in other words, 16 bits is likely to be more than sufficient if we have normal speakers, which may get to 110dB on peaks without frying, in a QUIET normal room.
If we argue for 18 bits, we have enough dynamic range to get from the noise level of the atmosphere to the loudest most speakers can get, and certainly to the loudest that the human ear should ever actually be exposed to.
If we want to reproduce a rimshot, up close, first we have to invent new speakers. We should also, in that case, encourage research in to hair-cell regeneration on the Organ of Corti.
If, just for kicks, we argue for 32 bits, we can go from the atmospheric noise level (6dB) to +4dB re: 1 ATMOSPHERE RMS. Of course nobody can realize that level on the negative excursion side, and any one device is only likely to render it on the positive side for one use...
J. D. (jj) Johnston
Reply #184
I know where you are coming from.  You are saying "you can't possibly create new information" in decoding 16 bit data at 24 bits.  True - you can't, but the key is that sound is well correlated.  If we were talking about random noise, then it wouldn't work.  But sounds that come from real instruments have amplitudes that don't jump around a whole lot between samples.  So I would argue that doing an interpolation (and in fact much better than a linear interpolation) is valid.
In terms of "creating information," you aren't - you're just guessing that the source of the sound was correlated.  And since uncorrelated things sound awful, this is a good guess.
The frequency components of the actual sound are limited (real instruments have limited overtones) and therefore the vorbis encoder can store these limited number of frequencies and get very close to the original sound.
Reply #185
Ofcourse the values can't jump around a lot between samples... that's what you ensure by low-passing the signal before a/d conversion.
What you want to accomplish - interpolating out the "steps" in the digital signal - is exactly what low-passing after d/a conversion does for you. And indeed that's better than a linear interpolation.
Seriously, your statement that the Fourier coefficients are quantized says it all. There is no improvement - the errors are now in those coefficients and will still sound the same.
Maybe you shouldn't have pointed that out
It serves no purpose at all for making your point (everything else in that post did not rely on the atomic structure of air), plus it seems to suggest that the discreteness of gasses would justify the discreteness in digital audio... that discreteness is on a completely different scale, and for all audio reproduction purposes on earth (not in outer space) we can consider air a continuous medium, I think
Reply #186
Actually, it sets an absolute lower limit on what detectable noise from an audio system can be, and I did that, ergo it is rather germane to the discussion. Since that sets a peak level of 98dB or so for a 16 bit system that meets that constraint, as I pointed out in that post, that rather does tie in to most audio reprodction.
Perhaps it seems to do so to you, it certainly relates to discrete levels in audio for me, since it does show, quite indisputably, the lowest useful level, EVER, for actual reproduced quantization noise.  It does not assert that any particular form of discrete system is the right one, or that systems even must be discrete.
Since (we do remember our QM, yes?) all systems in the real world ARE discrete, your point seems rather pointless, as it were.
Really, I don't think so. Just look at sound propagation through air as a function of moisture content. Right then and there, the issue rises its ugly head again.
As to "on a completely different scale", I have no idea what you mean. In fact, the threshold of hearing is very near the level of atmospheric noise at the eardrum, and very near the potential low-level noise of a 16 bit system set up for a reasonable playback level.  That is hardly "a completely different scale" it is very, very much on the same part of the scale, and very very nearly equal. So whatever DO you mean?
J. D. (jj) Johnston
Reply #187
Hey, no need to bring out the all-caps
OK, I have reread your post - and think I get it now. The point is that thermal motion would account for 6dB SPL already, right? I read too fast the first time, and missed that connection  Also, now that I'm getting the message, I'm quite stunned by the fact that the absolute threshold of hearing would be this low.
I think I remember some QM  But what effects that we're discussing would be lost in a classical treatment?
My point is that quantizing the audio signal would be just as legitimate if the real world was not discrete in any way. So I was thinking that bringing that point up blurs the discussion (and we're only making it worse now ).
Different scale: I meant that the sheer number of atoms that touch your ear drum every "integration time" (of the sensory nerves, that is) would be such that there's no point discretizing that. Thinking some more about that and your point about thermal noise: can't we predict that 6dB thermal noise level within the framework of classical thermodynamics, without thinking of independent particles? edit: hmmm, I guess not... a classical gas pressure could just generate a constant force...
Reply #188
If this is off-topic, I apologize...
I assume the thread (currently, at least) is only addressing the "why 24bit/48kHz/96kHz" issue for playback only purposes.
There are several reasons that recording, mixing and processing should be done at higher resolution and/or sampling rates than the targeted playback format, especially for music sourced from large #s of individual tracks...
-brendan
Reply #189
It's not clear that it is, but it's within 5 dB at the frequency of your ear canal resonance.  Needless to say it's hard to run this experiment.
Well, amplifiers, the atmosphere, etc, would be a whole lot quieter
Well yes, I don't think that's in dispute, however, the quantized nature of the universe does set lower limits to perception and electronics, and those lower limits are NOT very much smaller than our perceptions.
Exactly. But the force isn't constant.
Just some numbers. 1 Atmosphere RMS is 194dB SPL. We can hear to about -6dB SPL at our ear canal resonance. That's a factor of 10^20 in energy, or 10^10 in amplitude. Yeah, we do hear really small variations in air pressure at audio frequencies. Really small.
Fortunately we don't hear low frequencies at all. Consider the implications of a change in barometric pressure caused by a cloud going over. That's nothing but low-frequency, nonlinear acoustics. Consider the SPL, too, strictly speaking. Yeah, milliHz, fortunately.
J. D. (jj) Johnston
Reply #190
Yes, I have searched the forum.
Yes, maybe I am dumb.
But it seems I cannot find the answer.
Why do we need 24bit/48kHz/96kHz/192kHz if 16bit/44.1kHz is good enough? Are there any situations that 16bit/44.1kHz simply cannot satisfy? In other words, is there any real need for the higher bit depth and sampling rate?
Thanks for answering.
-brendan
brendan,
you answered right(There are several reasons...) but William don't ask for playback only purposes.
for editions we need more than 16bit(dithering is horrible)
Reply #191
This has nothing to do with quantization. It deals with sample rate. When the amplitude doesn't jump around in both directions between samples, it means that there are no high frequencies, and that a low sample rate is enough.
When amplitude doesn't jump around much in a given direction, it means that the sound is quiet.
In QM, the cinetic energy of a free air molecule is not discrete, but continuous.
Reply #192
Fascinating discussion.  Excellent question.  Check out the book by Malcolm Gladwell called "Blink".  There is report in this book of a double blind taste test conducted by Pepsi which proved that on the single sip, people much preferred Pepsi over Coke.  Coke then conducted their own double blind taste tests using the single sip taste test, and confirmed Pepsi's results.  As a result of these tests, Coke reformulated their recipe, and the rest is history.  In case you missed it, the new Coke failed miserably in the market.  Why?!?  Taste tests proved in double blind tests that the new formula was a winner.  The reason the new Coke failed was the very nature of the sip test, it was too brief a test.  It didn't reflect the days and weeks of using a product that on the initial test, won.  If buyers took a case of pop home, the results were completely different from a double blind test.  Coke eventually went back to "Classic" Coke, then the "New" Coke quietly dissappeared from the market.
Now lets apply the lesson from this to audio.  16 bits may be enough for a brief listen, but if you listen day after day, week after week, month, 16 bits aren't enough, I can hear too many limitations on my mid-fi system with 16 bit audio.  I can hear it when a 16 bit music CD is truncated as it fades to silence, and I hate it.  I want more.  To heck with double blind audio "sip" tests.  I want more.
Reply #193
Prove it.
There is no trunication.  Theres a noise floor, and the as the signal gets quieter it vanishes under quantinization error.  It seems to me you've fooled yourself into hearing things.
Reply #194
What kind of analogy is that?
I don't even bother to explain anymore.  I guess reading posts about how a WAV sounds better than a FLAC just killed my enthusiasm... (head to head-fi.org if you need to laugh a bit...)
No wonder there is a market out there for all kind of "stereo-snake-oil" products... there is a world of suckers out there !!
Reply #195
What kind of a reaction is that?
Don't take this wrong, I know the feeling, but if you don't bother to explain, just don't post
Taz PA-C: nothing in abx protocols forbids you to listen for days and weeks...
Reply #196
Blind listening for days have even been done recently : http://www.hydrogenaudio.org/forums/index....showtopic=45432
The results ? People gets much worse results than listening for seconds. Psychological illusions seem to grow up and reinforce themselves day after day.
The failure of the new Coke taste can be explained by the fact that people have liked the old taste for years. It was a traditional product. Change the taste, for better or worse, and it is no more a traditional product. It is a new attempt from beginners, made by chemists and mathematicians instead of gastronoms, welcomed with suspucion.
That's now how a drink should be made, thus it has to taste bad. The psychological effect is at work, and makes people dislike the new taste, or not even try it.
Reply #197
If you hear artifacts (grainy sound e.g.) when music fades to silence it probably means that either your monitoring system (DAC) or the audio on the cd (or both) hasn't been properly dithered. With correct dithering the sound will smoothly fade into the (dither-)noisefloor, which should be at such a low level (1LSB is about -90dBFS) that it's almost or completely inaudible under normal listening conditions.
Properly dithered music can still sound decent at very low levels (<-80dBFS).
Reply #198
good explanations Kees de Visser
the "issue" that i don't like in 16bit is that after each effect applyed(volume,equalize,etc) in the source when editing encrease the noise floor is summed one more time.
then,after some effects you can hear clearly the "white noise"(hiss)....too bad.
Reply #199
What software edits in 16 bit precision?  Even winamp plugins from the late 90s use floating point.
