Topic: spectrogam (Read 946 times) previous topic - next topic
spectrogam
Why is it not showing DSD 2.8 visualization?
Re: spectrogam
It is impossible to visualize DSD without converting it to PCM first. Either configure your DSD player to convert and output to PCM, or live without visualizations and other PCM processing.
Re: spectrogam
I assume you're using the sacd iso component. In that case, check the settings and select "DSD + PCM" output mode.
This will output DSD (if your hardware supports it) but also enable visualizations as if it was PCM.
