Topic: [0.9.5] Selection properties - Value Column - Resize (Read 1683 times) previous topic - next topic
The Value column resizes itself to the longest field (for me, that's usually File Path), and this seems to be causing a problem.
If I adjust this size to something smaller (to hide the horizontal scrollbar, typically) when I select a different playlist item, It will readjust itself to the longest field again. Is this the intended behavior, or a bug?
(Because it's buggin' me )
elevatorladylevitateme
