Topic: lyricshow for foobar2000 0.8x (Read 10514 times) previous topic - next topic
lazy to post the feather here, the zip file has it.
download the lastest version here
Good good study, day day up, :)
[span style=\'color:red\']The superman is the meaning of the earth.
Let your will say: the superman shall be the meaning of the earth![/span]
Been waiting for this for a while, thanks.
Could you make it possible to maximize the window?
thanx a lot dude! first time i've used it.. and it rocks!
is there anyway we could add a color gradient in the background of the window, or an image even?
everybody's a jerk. you, me, this jerk!
At first the plugin works but then after closing/opening foobar a few times it stops working. Deleting foobar.cfg will make it work again. I've attached a screenshot of the error shown in the core preferences.
I have the same error as ZhuGeLiang since i first installed the plugin.
Hero.Hua, could you please fix?
Thanks for the good plug-in.
I would like to ask some features inside this plug-in.
When I activate the Lyricshow plug-in, there is always a window title bar.
But, sometimes I think that it would be better if there is only the Lyricshow window without a window title bar.
I mean,
Now,
:L LyricShow v0.17a                                                          _      X
  blah, blah, blah.. (Lyrics shows here..)
What I am asking..
Could you give us an option to choose between two?
Hero.Hua,
I use your plugin in "Multi Lines" mode: could you please modify it so that it doesn't remove blank lines?
TIA.
Alessandro
Hero.Hua,
TIA.
Alessandro
solution:
give the blank line a timestamp
can do that via another plugin: lyricmake
download LyricMake plugin here
it can help you make the right lyric, only click your mouse
Hero.Hua,
TIA.
Alessandro
solution:
Thank you for the hint, BUT...
I have several (5-600) MP3s already tagged with lyrics (no timestamps): that would be a very long and boring job.
So, if possible, I'll be grateful if you can add this feature to your plugin.
TIA.
Alessandro
I think that would be impossible.
You would need something to read the wave and detect the vocal and then match it with the lyric, pretty hard.
But. Konami is kinda doing it with the new Karaoke game. So it *may* work.
Perhaps I wasn't clear: what I'm asking is to simply leave the blank lines that are in the lyrics source... that should be reasonably easy.
Of course I'm not asking for a tool that automagically puts the timestamps in my lyrics.
Alessandro
Yea that would be good
And yea, I thought you wanted it auto tagged, sorry
That would be pretty crazy though
Hero.Hua,
TIA.
Alessandro
new version 0.1.8.5 can support this feather
not only that, but also support this format:
[xx:xx.x]aaaaaaaaaaaaaaaaaaaaa
AAAAAAAAAAAAAAAAAAAAAAAAA
[xx:yy.zz]bbbbbbbbbbbbbbbbbbbb
BBBBBBBBBBBBBBBBBBBBBBBBB
Thank you very much!
Is it already available for download (and where)?
Alessandro
[Edit]Ok, got it! Thanks again: it's perfect now.
Alessandro
all discussion moved to :
http://www.hydrogenaudio.org/show.php/showtopic/9874
Support!
I remember lyrics show is my first lyrics-support software.
It's so cool.But it can't auto download lyrics by itself.
Minilyrics can do it...
.::No Pan No Gain::.
"$if(%artist%,%artist%' - ')$if2(%title%,%_filename%)"
Using Lyrics File name like this, can be found.
But I have some lrc files are like this,so it couldn't be found.
How to custom the Lyrics File Name can be found?
Lyrics Show only seach the file's name like this...
It's ok now...
I found it
