Topic: libfdk_aac for encoding AAC: Where and how do I get it (Read 36770 times) previous topic - next topic
According to various guides, like this one:
https://ffmpeg.org/trac/ffmpeg/wiki/AACEncodingGuide
The best AAC encoder to use is libfdk_aac, the Fraunhofer FDK AAC codec library. FFMpeg supports encoding with it.
However, I have been searching Google for hours now on how to get the Fraunhofer FDK AAC codec library, to no avail. Apparently, no one wants it, or no one has ever asked about it? I'm VERY VERY confused.
Where would I go to purchase libfdk_aac? How would I install and configure it to work on Windows with FFMpeg?
Can't for the life of me believe or understand why there isn't a single FAQ or guide written to explain this extremely basic and fundamental information.
Please forgive my attitude, I'm just VERY frustrated right now and I do realize I am probably being extremely idiotic and missing something VERY basic.
If I'm not mistaken Fraunhofer AAC is included in Winamp.
Note that the FFMpeg page fails to mention a few other common AAC codecs. This relatively recent public listening test seems to indicate that QuickTime is at least as good as Fraunhofer. You can get all of its functionality on Windows with the QAAC tool if I'm right.
Hi
You would need to compile FFmpeg yourself configured with options including "--enable-nonfree --enable-libfdk-aac".
There's some information at the Zeranoe forum here ---> Zeranoe forum
But it's not an 'easy' job.
Otherwise, try to find the program "fdkaac.exe" using google, or compile it yourself.
You can easily create a working ffmpeg with this script https://github.com/rdp/ffmpeg-windows-build-helpers/ (in a linux box or linux VM). It really does not take a lot of effort, just read the readme, everything else is automatic.
Re: libfdk_aac for encoding AAC: Where and how do I get it
i know the feeling.  so i did some looking and tracked down QAAC and after going through a few other links, came across the page with compiled versions or something.
https://sites.google.com/site/qaacpage/cabinet
I noticed it had an fdkaac archive in it.  I dunno, might be better than nothing.
PS: i found that link from this page, https://sites.google.com/site/qaacpage/
No, it's another FhG encoder.
Do you specifically need it included in ffmpeg? I have 32 bit and 64 bit compiles of the 'standalone' encoder, if that's any good to you.
fdkaac is present in Arch Linux repositories, so if you use Arch Linux or a derivative like Manjaro, you automatically have easy access to fdkaac.
Where are these builds ? I can't find them on your site :(
www.rarewares.org/files/aac/fdkaac-1.0.0-x64.zip
www.rarewares.org/files/aac/fdkaac-1.0.0-x86.zip
Wavpack Hybrid: one encoder, one encoding for all scenarios
Thanks! :)
fdkaac isn't bad encoder but its bitrate inconsistency is hardly tolerant.  It ends up with 75-80 kbps for HEAAC  VBR mode 2 when target bitrate is 64 kbps.
Despite this bitrate bloat fdkaac is still somewhat inferior to Apple HE/LC- AAC encoder.
Not recommended.
