Topic: [request]Tag Mass-renamer (Read 2370 times) previous topic - next topic
Does anyone remember ID3 TagIT?
Well it had an awesome feature, that is basically the reverse of the mass-tagger's "Guess info from filename" feature.
Basically, what would be awesome in foobar is if you could rename a group of files based on the info in the tags, so say your current layout was %artist% - %album%\%artist% - %title%, but you wanted it to sort correctly (and had fully correct MP3 tags) you could select a "mass rename" preset of (what I'd use) is %artist%-'['%year%']'%album%\%tracknumber%-%title%, similar to ID3 tagit. Also, after the rename is complete, it could remove the current entries, and then re-add the new files to the playlist.
hi
I don't understand your request,
as far as I understood, the masstagger move/rename files is already able to do this..
it's there and it's here:
context-menu:
foobar 0.8: Masstagger > 'move, rename or copy files'
foobar 0.9: File operations > 'move, rename or copy files'
[a href="index.php?act=findpost&pid=301145"][{POST_SNAPBACK}][/a]
Oh yeah, sorry
Lock please
hi
