Topic: Columns UI appearance (Read 3287188 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
Reply #500
Reply #501
Reply #502
After years of using the Default UI, this is my first own PSS setup, I didn't want transparency so I went with black, duh ...
[a href="http://xs.to/xs.php?h=xs137&d=09120&f=screen616.jpg" target="_blank"]
Reply #503
@qwertz
Looks very good
Reply #505
Thanks tedgo
btw, for whoever is interested in better art view, I found a little program that really integrates well with foobar.
link
Reply #506
Any chance to get this?
Reply #507
I made some updates on my layout.
"I never thought I'd see this much candy in one mission!"
Reply #508
Very nice config.
I can see two WSH seek bars in your config. One is displaying the total playback time of the album and the other is displaying the track playback time (if I'm right).
Do I need el_playlist to implement the album total playback time in WSH? If possible I would like to implement this with CUI only.
Thx in advance.
Regards
Reply #509
I think the left one is a seekbar and the other one is just a volume bar
Reply #510
oh...yeah.
What a pity.
Still looking to solve the elapsed playtime problem....
Beside that: is in CUI something like group count (like in EL_PLAYLIST) available?
As I said, I would like to stick with CUI only...EL_Playlist is great. But I want to keep my foobar config lean...
Reply #511
When I find time to clean up the code, sure. As it stands, there is no nice and easy way to setup this configuration, I wasn't very organized while creating it  Plus there is a lot of code in there that is only useful to me, and only of marginal interest to others.
Yep, that's it.
oh...yeah.
What a pity.
Subjectively ELPlaylist, if at all, is only minimally slower than NGPlaylist, as long as you turn off transparency, that is.
Reply #512
Can someone give me a link to the album art panel download? I cant find it anywhere. also, post your track info codes! some of them are really nice
Reply #513
ELPlaylist keeps all the title formatting crap to itself at least.
Someone should marry WSH Panels with ELPlaylist and then use JScript for everything. Even Panel Stack Splitter could be merged into it.
Like WSH for everything. You just need to add the proper objects and methods to be used from JScript.
Just with the basic drawing commands and event system I could make a simple painting application out of WSH Panel so then just imagine what else you could possibly cook up.
Time to finally get a proper skinning system for fb2k instead of all these half-assed components.
Reply #514
@saivert
Really good idea
My dreams would come true if there would be something like "foo_wsh_splitter" (as replacement for the PSS) or "foo_wsh_skin" (as a new skinnable user interface) instead of those crappy TF "abusing" elements. But there is none at the moment...
There was a thread about something similar a few month ago (replacement for Panels UI using XML) .
I hope one day there'll be a clever guy who creates something like that
Although i doubt it would be widely in use.
I remember gfx_window that uses lua...
Reply #515
So there is no way with CUI only for the group count thing?
What I also really need and its hard to find: plugins with a proper keyboard control. I'm using foobar as my hifi player and therefore I need to navigate trogh foobar with my remote control. This requires a proper keymapping...works fine with the filters from CUI. Once I start adding PSS etc. things become difficult.
Unfortunately I didn't find any way to map keys buttons etc.
Reply #516
A work in progress.
Reply #517
Very nice colours. Good work
Reply #519
tmt that is great looking
Reply #520
I'm having a little beginner's trouble with Columns UI. First off, I can't see straight up what it does better than the Default UI. Secondly, where can I browse usermade preset themes?
Reply #521
... Secondly, where can I browse usermade preset themes?
I'm also new to foobar & one of the best places I have found for preset configs is DeviantArt HERE. You need to read the descriptions carefully however as some are PUI (Panels UI) and some are CUI (Columns UI) configurations. The PUI configs won't work with the most recent foobar versions.
Some of the better (in my opinion) configs I have found are: DarkOne, Kameleon, & Curacao. There is a big enough variety however to suit anyone's taste and once you start messing around with a config (and with some help from these forums) you can pretty easily tweak it even more to your tastes.
Reply #522
perfect, cheers!
Reply #523
My tabbed layout with lots of use of custom buttons
hey, very cool. what's the plugin you use to get those album/artist images remotely?
It's foo_run and AlbumArtDownloader, both highly recommended. The former is a plugin that can call external programs. The latter is a stand-alone program which can also be set up to read your foobar Media Library. If you need any help setting it up let me know
Reply #524
is ther any way to make album art download 100% automaticly? I now have to press a button, AAD will appear and i have to press a second time to download the art.
