Topic: Format from Other Fields - How to remove old patterns? (Read 1533 times) previous topic - next topic
Hi
Under properties metadata, there is the possibility to fill fields by "Format from Other Fields" (right-click context menu). I have several old patterns there in the drop-down menu, which I would like to remove. How do I do that? Could not figure it out and have not found any documentation.
Thanks for your help!
Re: Format from Other Fields - How to remove old patterns?
Select the preset you want to remove. Right-click on the drop down arrow or the border of the listbox, and choose "Remove this history item".
Thank you very much j7n! That was the solution I was looking for. Is this documented somewhere? I've tried to find a solution on the web before. Anyway, it is now documented for eternity in this post. 8)
This has been asked before on the forum. No other documentation that I am aware of mentions this function. The same preset management options are available on a few other combo boxes in Preferences. The delete function isn't really discoverable. In other places I would typically see a Delete button next to the listbox (as in the DSP manager or File Operations).
