Topic: [Bugs, IOS] Capitalization | Tracks Hidden (Read 397 times) previous topic - next topic
#1
On IOS foobar2000 1.3.1, albums will retain previous capitalization values even if they are changed. For example I downloaded an album where the capitalization was standard (first letter of each word), but then I removed it from my phone, changed all the titles to lowercase, and upon redownloading it, all the capitalization was still standard. Would it ever be possible to allow for clearing of cache like this? The only way I've found to solve this is to copy and paste "look-alike" characters into each title affected, so as to make foobar think the titles are different.
#2
If I download an album that maybe has multiple discs, but on each disc there is a track with the same name, only the tracks from the first disc will appear; this happens even with the "Hide duplicate tracks when browsing" setting off in Advanced. For example, Vomir/Trou has eight "discs," but on nearly every disc there is an untitled track, which results on only the first first untitled track from each artists appearing. The only way I have found to solve this is to put each disc in its own folder.
Re: [Bugs, IOS] Capitalization | Tracks Hidden
Are the ID3 tags for Disc Number and Total Discs filled with values?
yes, and the discs are also in the file names (for example: disc three track two is "3-02. [untitled].opus")
