Topic: tgpo Foobar Config (Read 43099 times) previous topic - next topic
tgpo Foobar Config
I have a problem, I installed it and downloaded all the plugins, but it won't play anything when I double click.
Just for testing, if you revert to default UI does it play the files?
Also, will it be possible to make it show the bitrate of albums? As in V0, V2, FLAC, etc?
Anything is possible.  I'll see what I can do.
How did you make the volume bar active on mouse over with the wheel?
Someone else coded the volume bar script.  I found in on this forum somewhere.
Are there any shortcuts to switch through viewing modes?
Nope.  I'm unsure if that's even possible, but I'll look into it.
Hi, nice new re-design. Though i have found a slight problem, besides full mode(which looks good with the album art but everything else ain't right),
I'm a fix size guy, remember  At least this was a step in the right direction for you, right    I'll try and get more and more fluid size for you and other people who like full screen modes.
i noticed when i have the play list at start up instead of the mini-mode, and when i hit play i see a piece of my album art at the top track info part. But when i click like mini-mode, or browser, and then click back into the play list the album art disappears and appears normally without it. Can you fix this?
Nope, but you can.  When you made the Playlist be the startup panel, you didn't make the Track Info Mod be hidden at startup.  If you have playlist be the startup panel, then the Now Playing panel should be shown instead of Track Info Mod.
Edit: Also, when i re size the window a little bit to show the track ino panel a little more when clicking the GB, graphical browser(acutally clicking any of the buttons) then  it re size the window back to the way it was instead of keeping it (the way i changed it too)
All part of my fixed size nuances.  As I make the design more fluid this will fix itself.
tgpo Foobar Config
That fixed the album art issue thanks, but it does not display the artist, title,etc... now unless i click another button. NOT a big deal or anything.
Edit: Still though you have that gap between the sides of your track info, the border, and i do not, unless i resize this. DO you know why? I think it's weird that it doesn't.
tgpo Foobar Config
I'm trying to install tgpo v1.1 but when I try to import tgpo.fcl, foobar would crash and give me this a long error message:
Illegal operation:
Code: C000001Dh, flags: 00000000h, address: 011A738Eh
Call path:
entry=>app_mainloop=>Create splitter host
ETC.....
I tried both foobar2000 v0.9.5.3 and foobar2000 v0.9.5.4. It still crashes.
I unzip tgpo.zip with the following folder structure:
"C:\Program Files\foobar2000\themes\tgpo\images"
"C:\Program Files\foobar2000\themes\tgpo\tgpo.fcl"
NOTE: I do not have the settings folder as mention in step 4 of the instruction. The zip only contains images folder and the fcl file. Maybe it's the missing settings folder causing crash?
Below is the list of components I installed in the foobar component folders:
WSH Panel (uie) 0.7.2  (foo_uie_wsh_panel)
Default User Interface 0.9.5  (foo_ui_std)
Album List 4.2.2  (foo_albumlist)
Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]  (foo_uie_trackinfo_mod)
CD Audio Decoder 2.1.2  (foo_cdda)
Standard DSP Array 1.0  (foo_dsp_std)
foobar2000 core 0.9.5.3  (Core)
Panel Stack Splitter 0.3.4(alpha)  (foo_uie_panel_splitter)
Album list panel 0.2.3 beta  (foo_uie_albumlist)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
ReplayGain Scanner 2.0.6  (foo_rgscan)
Single Column Playlist Display 0.5.4 beta [Jan  9 2007 - 15:42:59]  (foo_uie_single_column_playlist)
Graphical Browser rev015  (foo_uie_graphical_browser)
Playlists Dropdown 0.6 alpha 4  (foo_uie_playlists_dropdown)
Converter 1.1.1  (foo_converter)
Columns UI 0.3 beta 2 preview 11e  (foo_ui_columns)
Any suggestion of what is causing this crash? This is my first time installinga  foobar config.
Tgpo thanks for this sharing this awsome config. It's your config makes me want to switch to foobar from AMIP2.
Any help would be greatly appreciate it.
Kenneth
UPDATE: After a little more research, I find out it was the foo_uie_wsh_panel that is causing the crash. Since some of you got it running, is there a special requirements or installation to get it to work?
tgpo Foobar Config
I had some internet problems and fixed the issues I had with it . Thank god for consoles showing error messages! The problem was that for some reason foobar didn't auto detect the Output Device and it acted as if I didn't have a sound card.
Now, a few suggestions/requests
1. Can you make it so that when I click on the Artist/Song showing above the seekbar it will find that current song on the playlist and show it on screen?
For instance you're browsing down your playlist and decide you want to jump right to the song/album you're playing but instead of looking where it is just click on the name above the seekbar and it will automatically get you there.
2. The ability to sort the playlist. Right now it adds everything in the bottom, but I want to sort it so it's easier to find stuff I'm not particularly looking for - band/album/year.
There is a "View" context menu when you right click on the side border of the application but it does absolutely nothing.
3. Can you make it possible to drag the whole window by clicking and holding somewhere outside the playlist?
[a href="http://www.imagebam.com/image/89f86f9068767" target="_blank"] Is it possible to make the seek bar act the same as the volume bar when the mouse is hovering exactly over it so you can also seek with the scroll?
10a. It would be great if it also showed the year of the album, next to the name or genre or # tracks.
11. What should I do to make it show special characters (such as the Y in Queensryche)?
[a href="http://www.imagebam.com/image/a4c7069069314" target="_blank"] Great job! You should also post it on deviantart
tgpo Foobar Config
ActiveThoughts, can you take a screenshot of what you mean about the gap, or is it already shown in one of the previous pics?
Glad you like it.
WSH panel is picky about what hardware it will stably run on.  Some hardware configurations it just refuses to not crash on.
The fix to this is to replace WSH with the seek bar.  It's not pretty, but it's stable and gets the job done.
I'll come up with a non WSH config, because others requested it as well.
@Janny,
I'll go through later today and address your list, I'm 2 minutes from leaving for work.  Some of your requests are outside the scope of what a config can do and are actually foobar2000 requests.  I'll be sure to note these when I go through it later today.
Thanks for all the feedback thus far.  I know the config isn't as exciting or large as others out there, but I'm glad to see there are other like me who don't need a lot of flashy graphics to enjoy their music.
tgpo Foobar Config
Hi, it's in the previous picture, the first and the second one. ON the left side you'll see the very tiny gap, and the right has no gap, the second picture with the green line shows the small gap(i had to re-size the window to show the gap on the side) i hope that helps,
tgpo Foobar Config
Are you in Vista?  The reason I ask is because your window border is much larger than what my XP uses.  I would speculate that the extra thickness of the border is causing this issue.  I would image that as I work through and remove my fixed width and go to a fluid width design this issue will correct itself because it will be doing the math of how much space it needs.
tgpo Foobar Config
Reply #32
[quote name='Janny' date='Jul 9 2008, 04:45' post='575942']
[/quote]
I don't think that's possible.  That would require the two components to interact with each other and share data.
[/quote]
This will be in a later release.  I want it too.
[/quote]
You could do that, but wouldn't the audio be jumpy as you scrolled?
[/quote]
I'll try to work it in for a later release.
[/quote]
That's either an issue with the Track Info Mod component used to display the info, or the font I used, Arial.  If you have the band name in a text program and have the font set to Arial, does it show the special character?
I really love this design, I'm currently thinking of keeping it as a default one. It's not huge, it's easy on the eyes and stylish. It would have been great to be able to see the whole artwork but it's not a big deal. Minimalistic is good too  Great job! You should also post it on deviantart
[/quote]
Thanks, glad you like it.  I went back and forth on the album art issue and eventually figured that the point of the player isn't to see the art, it's to hear the music.  I figured people would pull the cd out if they wanted to see the full art, 300x300 images don't do some covers justice.
tgpo Foobar Config
Thanks. I'll look forward for the non WSH config because I really like how you layout the UI. This should be the default theme for Foobar.
Tgpo, I created an install.cmd that will automatically copy the installation files to foobar folder without do it manually. You can create two installaion. One without the components and one with components in the folder. Would you be interested? If so, I'll email it to you.
Kenneth
tgpo Foobar Config
Reply #34
tgpo, thanks for the reply, i should have mentioned that i do in fact use Windows Vista, is there any fix possible? Or you can't because you do not use this operating system at this time.
tgpo Foobar Config
Reply #35
Although I can't test it, my hope is that by killing the fixed width code it will auto adapt to the added border width.  We'll see.
tgpo Foobar Config
Reply #36
sounds good man, thanks for even trying to help with this issue. (since it doesn't affect the playback it does not bother me all that much) just cosmetic.
tgpo Foobar Config
Reply #37
This looks great.  I'd love it if you could incorporate lyrics and ratings in the future.  I'd gotten used to changing my PUIs fairly often, and now that the evil admins have killed that off I've been stuck with the same one for quite a while.
tgpo Foobar Config
Reply #38
We'll see about lyrics and ratings.  I'll add it to my list of things to mess around and work with for possible addition.
tgpo Foobar Config
Reply #39
Sorry for the way I reply, but there's some problem with the quotes and it gets even more frustrating who said what
1. On my other config, when I press on the artwork it jumps straight to the song that's playing, but the other one is using PanelsUI, maybe this has something to do with it.
3-4. Again, this is possible but on the other config, PanelsUI. Damn.
5. Albumlist is installed as well as Album List Panel.
6. Did it, no results.
7. Unfortunately you're right. PanelsUI allowed this, but not Columns.
10. Not necessarily if it acts as a keyboard shortcut - one scroll = 5 seconds (for instance). But I agree, kinda pointless.
11. It was an issue with the font. I changed it and it shows everything now.
tgpo Foobar Config
Reply #40
I'm guessing 5 & 6 go hand in hand.  Because it isn't finding your music, the 4th view mode has nothing to display.
I'm unsure why Foobar2000 isn't seeing your music, it may not like the @ in the folder path.  Try it without the @ and see what happens.  If the problem persists, post about it in the support forum and see if some developers can offer further insights.
tgpo Foobar Config
Reply #41
I've added a to do list to the top post.  This way everyone will know what I'm working on and we won't repeat requests.
tgpo Foobar Config
Reply #42
It's not the @ in the path because the older foobar with those plugins recognizes everything. I messed around with it, removing one plugin, then replacing it etc. but the only thing I managed to do is fuck it up completely lol,
now it looks like this. First pic is the album list panel (fourth button) with a right click on it (if you look on the previous page when I posted screenshots, it looks different there). I deleted the config folder, added it again but the result is the same:
tgpo Foobar Config
Reply #43
Sweet!!! I can't wait for the non-wsh_panel version. I tried on three computers and Foobar crashed on all of them. Thanks again for your dedication and time on this config. This is one of the best theme as of right now.
Kenneth
tgpo Foobar Config
Reply #45
anxiously awaiting the fluid size  really enjoying this config
tgpo Foobar Config
Reply #47
Any word on lyrics or ratings?
