impulse_trigger_profile 5&6 issue
Reply #20 – 2005-08-09 00:27:52
(...) aoTuV beta 4 introduces almost the same result as if you'd tinker the 1.1 ITP's to death in search for the proper quality/size and microattacks/noise values. Is it based on listening tests? I've just started a small test with one critical sample (castanets2.wav - well known here) only (I must go to bed): 1.1.1 -q6 -q --advanced-encode-option impulse_noisetune=-15 aoTuV beta 4 -q6 aoTuV beta 4 -q7ABC/HR Version 1.0, 6 May 2004 Testname: 1L = C:\temp2\preecho\castanets2 [1.1.1 q6 IN-15].wav 2R = C:\temp2\preecho\castanets2 [aoTuVb4 q6].wav 3R = C:\temp2\preecho\castanets2 [aoTuVb4 q7].wav --------------------------------------- General Comments: --------------------------------------- 1L File: C:\temp2\preecho\castanets2 [1.1.1 q6 IN-15].wav 1L Rating: 4.8 1L Comment: --------------------------------------- 2R File: C:\temp2\preecho\castanets2 [aoTuVb4 q6].wav 2R Rating: 4.0 2R Comment: --------------------------------------- 3R File: C:\temp2\preecho\castanets2 [aoTuVb4 q7].wav 3R Rating: 4.5 3R Comment: --------------------------------------- ABX Results: C:\temp2\preecho\castanets2 [1.1.1 q6 IN-15].wav vs C:\temp2\preecho\castanets2 [aoTuVb4 q6].wav 5 out of 5, pval = 0.031 C:\temp2\preecho\castanets2 [1.1.1 q6 IN-15].wav vs C:\temp2\preecho\castanets2 [aoTuVb4 q7].wav 5 out of 5, pval = 0.031 C:\temp2\preecho\castanets2 [aoTuVb4 q6].wav vs C:\temp2\preecho\castanets2 [aoTuVb4 q7].wav 5 out of 5, pval = 0.031 To sum up: 1.1.1 -q6 impulse noisetune > aoTuV q7 > aoTuV q6 . Difference is not that great. aoTuV -q6 has still audible pre-echo with this critical sample, but it's not really annoying. By far, it was the easiest file to ABX. aoTuV -q7 and 1.1.1 IN -Q6 are very close each others, and pre-echo was very, very subtle. I've started to find a small difference during ABX test, which wasn't really hard to ABX (it surprises me). I did this test with the onboard AC97 component of my computer and a Philips HP910 headphone, which are not optimal. Conclusion (based on one small and critical sample ): aoTuV beta has low but audible preecho on critical transients, and pre-echo is lower with impulse noisetune -15 than with aoTuV beta 4.
