Topic: Mp3tag 3.14 Beta (Read 535 times) previous topic - next topic
Mp3tag 3.14 Beta
Mp3tag is a powerful and easy-to-use universal Tag Editor that allows to edit metadata of common audio formats where it supports ID3v1, ID3v2.3, ID3v2.4, iTunes MP4, WMA, Vorbis Comments and APE Tags.
It can rename files based on the tag information, replace characters or words in tags and filenames, import/export tag information, create playlists and more.
3.14a (2022-04-02)
CHG: added workaround for non-null padding bytes for INFO subchunks in WAV and AIF.
CHG: display format string syntax errors in preview field of converter Tag - Tag.
CHG: next sort doesn't invert order in case files were added to the file list.
CHG: optimizations regarding memory usage when refreshing a filtered file list.
FIX: changing cover properties did not work when auto-saving in some cases.
FIX: saving cover to local file did not work anymore when importing from Tag Sources (since 3.12c)
https://community.mp3tag.de/t/mp3tag-development-build-status
"Life's the same, I'm moving in stereo
Life's the same except for my shoes"
Re: Mp3tag 3.14 Beta
3.14b (2022-04-13)
NEW: added option to manage the list of filter expressions, including named filters and descriptions for filters.
FIX: MusicBrainz tag source issue when parsing joinphrases.
FIX: undoing after multiple tag copy and paste operations undos all operations and not only the last one.
3.14c (2022-04-13)
FIX: UTF-8 conversion issue when migrating the previous filter history to the new format.
https://community.mp3tag.de/t/mp3tag-development-build-status/455
3.14d (2022-04-23)
NEW: added option to manage list of format strings at converters 'Tag - Filename', 'Filename - Tag', 'Text file - Tag', and 'Tag - Tag', including named format strings and descriptions for format strings.
CHG: extended quick actions to remember previous inputs.
FIX: display of checkmark for moved filter items wasn't updated on move.
3.14e (2022-05-06)
NEW: added support for 64-bit
3.14f (2022-05-07)
FIX: potential data corruption when reading and saving configuration lists, e.g., field mappings or filter histories on 64-bit (since v3.14e). Please restore from backup before proceeding with v3.14f.
FIX: activating running instance and passing files and folders did not work on 64-bit (since v3.14e).
FIX: runtime error when adding cover art via context menu of cover window on 64-bit (since v3.14e).
3.14h (2022-05-08)
NEW: added note if running 32-bit or 64-bit version to about dialog.
FIX: runtime error when restoring previous selection when filtering files on 64-bit.
3.14i (2022-05-10)
FIX: LAME encoder version wasn't displayed on 64-bit.
FIX: dialog for managing format string or filter expressions had cropped labels in some languages.
3.14k (2022-05-16)
CHG: added support for editing track-specific metadata in tracks list at Tag Sources confirmation dialog.
CHG: use placeholders for current cover at action Export Cover.
