Topic: Feature Request/Feature Restoration - Load last location on app open (Read 2324 times) previous topic - next topic
When Foobar v1.4 (I believe) was released, it broke access to audio on my phone's SD card. In trying to troubleshoot I uninstalled/reinstalled the Foobar mobile app. That resolved the storage access issue, but ever since then when I open the app it loads to the main Foobar menu, not to the last location that I had open. Prior to v1.4, if I swiped the app closed from an album menu, or whatever was playing last, it would load right back to that screen. Now when it loads it goes to the main menu, and I have to go to Music on External Storage ->Artist folder ->Album folder to either get back to where I was or wherever I want to get to.
I know that I can just swipe left to get to whatever was playing last, but if I want to get to another album or artist folder from there, pressing the phone back button or swiping right doesn't take me up a level in the folder hierarchy like it used to when app open would load to where I was last; instead back/swipe right dumps me back to the main menu, so I still have to press through multiple menus.
It's a minor thing but it was very convenient when this worked properly, and now it's just an annoyance. I was hoping that it would be corrected in a subsequent release, but it has been a while since v1.4. If there is a setting that I am missing that would resolve this I would appreciate that info (Settings ->Advanced ->Resume Playback is not a resolution). I am running Android 14. Thanks.
Re: Feature Request/Feature Restoration - Load last location on app open
Hi.
Check it out for yourself.
Standalone Android APK downloads
version 1.5 preview 2024-01-11
https://www.foobar2000.org/apk
Foobar2000 Mobile:Version 1.5 Preview Change Log
https://wiki.hydrogenaud.io/index.php?title=Foobar2000_Mobile:Version_1.5_Preview_Change_Log
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
I already loaded 1.5. Didn't fix it. Unless I am missing a setting somewhere....
Where is the version you are using listed?
There should be no special settings.
Copy to internal storage or replace SD Card.
Change the folder name to a different folder and make it Media Library.
Anyway, please TEST rebuilding the Media Library
Many users seem to be experiencing issues such as not loading Tracks or Skin files from the SD card.
The version in the Settings ->About section is 1.5.0 preview 2024-01-11. I just tested with internal storage and I get the same result - if I close the app from the track that is playing, relaunching the app loads to the main menu, not to the track that was playing. I have uninstalled/reinstalled/rebuilt the library in previous builds without any resolution as well.
And if it matters I should mention that I am running this on a Samsung A53, which is running OneUI 6.0.
Users with the same symptoms have never seen a solution like this. In my case, the issue was resolved by updating foobar2000 mobile.
Please look forward to the update.
Any updates on this? No recent updates/preview releases have fixed this, and I am able to reproduce the issue on other Android devices...
My needs are the same as yours. I posted two posts, but it seems that I expressed myself incorrectly and no one understood.
Start the program and load it directly onto the playback page,
However, now it is time to load the main page or playlist page.
我和你的需求一样。发了2个帖子,好像我表达不对,没人看懂。
启动程序直接加载到播放页面,
但是,现在是加载主页面或播放列表页面。
For anyone following this issue - this has been almost entirely fixed in v1.6.0 preview 2024-06-11. If you are in a list of albums, within an artist folder, or in an album folder and you swipe the app closed, reopening it will take you back to where you were. The only thing that hasn't been fixed, and it is a minor item, is that if you have a track open in the app and you close it, reopening will take you back to the parent folder of that track/track list for that album, not back into the track itself, which is how it used to work. But again, minor issue. Big thanks to the team for fixing this.
I take it back, sort of. It is working only intermittently.
Last location on app open does not persist through a device reboot, and it randomly works/doesnt work on app close and reopen.
This is not a issue, it is a functional requirement. If there were three options, that would be great. Play interface, list interface, main interface.
实时翻译
这不是问题,这是一个功能要求。如果有三种选择,那就太好了。播放界面、列表界面、主界面。
@yisisixu
What does that mean? Please explain more.
Browse/Main interface
Artist, Album, Playlist etc.../List interface
Show playback controls/Now Playing interface
Now Playing Screen (My Skin)
So you want to choose between 3 screens at startup?
That's a good idea.
My 2 cents...I just want the app to load to wherever I was last when I closed it, regardless of how long the app has been closed, if the device was rebooted, etc. It used to do exactly that, several versions ago.
@Air KEN
I using this software on my car,
When the software starts, I need "Show playback controls/Now Playing interface"
Will show me how to set it up,please.
I hope there is an option to choose the starting position
and last location
It would be nice to have that option.
It would be best if you could choose from the following three options:
1.) Last Exit Screen
2.) Browse
3.) Playback controls (Now Playing)
@Air KEN
Every time the software starts, it always browses page
I need to swipe the screen left TO the playback controls
I would like save this step
ε=ε=ε=(#>д<)ノ  This trouble has been bothering me all along
