Topic: Exit code '00000001h' when converting with iPod Manager (using (Read 1145 times) previous topic - next topic
I've started re-ripping parts of my music library to the FLAC codec. Obviously this isn't supported by iPods however the iPod Manager component can convert on the fly.
I'm getting exit code '00000001h' from the LAME encoder when using the iPod Manager's "Send to iPod" function. However, conversion works fine if I use the regular "foo_converter" component.
Using parameters: -S --noreplaygain -V 0 --vbr-new - %d
I've also been searching these forums for a solution. Found this issue crop up a few times, but no solution.
O/S is Windows 7, and the iPod is a Video 5G (30GB) running firmware 1.2.1.
Thanks,
Adam Reece.
