Topic: CueTools not getting tags for 2025 releases (Read 359 times) previous topic - next topic
Hello.
Cuetools 2.2.6
I don't know what happened, but it seems that CueTools is not getting tags for releases in 2025. I have Bravo Hits 128, 2 CDs. Both CDs can be fetched from foobar2000 and MusicBrainz plugin by TOC, but CueTools is not showing anything. I can verify the rip, but in Select Best Match it is showing nothing from Musicbrainz, just to select CUE file, and the green one, I am guessing freedb. When I click MusicBrainz button, it leads me directly to Bravo Hits release page for that particular disc number.
What has happened, can I fix it, and if not, will it be fixed?
TAPE LOADING ERROR
Re: CueTools not getting tags for 2025 releases
https://github.com/gchudov/db.cue.tools/issues/22
AFAIK the MusicBrainz sync hasn't worked since 10/23.
Hopefully it will get fixed.
BUT I expect another MusicBrainz update next month would break it again if it were fixed now.  MusicBrainz usually updates mid May.
I would like to see direct access to MusicBrainz and AccurateRip Meta like already exists for freedb.
korth
