Topic: flac 1.3.0 pre-release (Read 67265 times) previous topic - next topic
  • hidn
Reply #75
anyway, slower and less compression than flaccl
  • Last Edit: 17 March, 2013, 08:17:48 AM by hidn
  • Case
  • Developer (Donating)
Reply #76
Other news: The FLAC git has seen some changes on 2GB file limits on Windows. I didn't full understand the mailing list conversation, but apparently the limit was raised to 4GB and this can't be fixed until 1.3.1.
The fix has no such limits. Only API wasn't allowed to be changed, but that affects nothing but FLAC__metadata_simple_iterator_get_block_offset function. That means this function won't work if there's more than 2 GB worth of metadata. I have tested the modified code with 20 GB FLAC files without trouble.
Edit: I added experimental Unicode support to flac.exe last night. If anyone wants to experiment you can download this.
  • Last Edit: 17 March, 2013, 08:59:48 AM by Case
  • ktf
Reply #77
Great stuff, can't wait to see it make it into git! Thanks!
  • lvqcl
  • Developer
Reply #78
Does -o option work? Because when I use "flac -6 in.wav -o out.flac" it creates in.flac and outputs:
in.wav: wrote 21869264 bytes, ratio=0,731
ERROR: output file in.flac already exists, use -f to override
If -f is added, it encodes the file three times.
  • IgorC
Reply #79
So now new FLAC decoder decodes -8 preset  faster than old decoder -0 preset.
Not bad.
  • db1989
  • Global Moderator
Reply #80
[coded support for files >2/4 GB and Unicode]
You’re on a roll here!
Also, more speed-ups? Great, but as if it wasn’t far enough ahead of all the competition already.
  • Last Edit: 18 March, 2013, 06:02:07 PM by db1989
  • Case
Reply #81
Thanks for testing. I had missed a couple of functions that took filenames. Appropriate fixes have been made and my own quick testing found no more problems.
I updated the archive with latest changes and added metaflac in too. It contains the same unicode and wildcard treatment.
  • Porcus
Reply #82
15 percent increase in decoding speed? It is hardly much compared to how CPU power has evolved over the years, but still cool in the 'just because one can' department. (After all, this is the yardstick I have been evaluating other codecs against; can it touch FLAC on both speed and compression simultaneously?)
  • birdie
Reply #83
I've compiled FLAC 1.3 pre3 with GCC 4.8 (vanilla) on i686 but it keeps crashing:
Program received signal SIGSEGV, Segmentation fault.
(gdb) bt
#0  0x08078685 in FLAC__bitreader_read_rice_signed_block_asm_ia32_bswap.c0b0 ()
#1  0x00000000 in ?? ()
Compilation flags used are:
-O2/-O3 -pipe -march=native
(I've got an Intel Sandy Bridge CPU)
I configured it this way:
./configure --enable-sse  --disable-shared --enable-static
  • birdie
Reply #84
It also crashes when compiled with GCC 4.5.4 without "--enable-sse".
It also crashes when I used "-O2 -pipe".
OK, I give up, I've just compiled it with "-O0 -g" and it just doesn't work at all:
file.flac ERROR got FLAC__STREAM_DECODER_ERROR_STATUS_FRAME_CRC_MISMATCH while decoding FLAC input
file.flac ERROR: while decoding FLAC input, state = FLAC__STREAM_DECODER_SEARCH_FOR_FRAME_SYNC
I run flac this way:
./flac -f -8 -Ax2 --replay-gain -V *.flac
(This is how my files were originally compressed).
I even removed most flags:
./flac -f -V *.flac
The errors persist (STREAM_DECODER_ERROR).
Guys, is some magic required to compile the new FLAC? It seems totally broken.
  • Last Edit: 04 April, 2013, 06:56:05 AM by birdie
  • birdie
Reply #85
GIT version has the same problems.
Sigh.
  • chi
Reply #86
Why are you trying to do a static build?
  • ktf
Reply #87
Static building never worked for me, but if you build shared, the flac utility will be static anyway (you'll have to run the script src/flac/flac and use src/flac/.libs/lt-flac after that), which does work here.
This release was mainly meant to fix built issues, so building should actually be easier.
  • chi
Reply #88
That’s not actually true, lt-flac is still dynamically linked. Libtool only makes sure that the uninstalled libFLAC is being used:
$ ldd src/flac/.libs/lt-flac | grep FLAC
    libFLAC.so.8 => /home/chi/devel/flac/_bd/src/libFLAC/.libs/libFLAC.so.8 (0x00007f419de57000)
Unlike a statically linked binary, this will stop working if moved (it may either silently use the system-wide library, if there is any, or fail).
  • ktf
Reply #89
Oh right, I've been fooling myself apparently.  Sorry for talking BS, thanks for the warning.
  • Last Edit: 04 April, 2013, 05:36:48 PM by ktf
  • Case
Reply #90
The problems birdie has look very much like broken hardware to me. Bad memory stick could easily trigger such behavior.
I uploaded fresh Win32 binaries of 1.3pre3 + git fixes here.
  • ktf
Reply #91
These are with the UTF-8 runtime patches you made? There are still problems with them (it actually got worse). I tested them on Windows XP SP3 and Windows 7 SP1, and I got this when used on three files, one with Cyrillic, one with Arabian and one with Japanese text.
See these screenshots:
http://www.icer.nl/misc_stuff/flac-130pre3-test.png
http://www.icer.nl/misc_stuff/flac-130pre3-test2.png
It seems it doesn't remove enough characters (doesn't empty the line completely) before writing a new step.
  • Case
Reply #92
Ouch, thanks. I used such tiny files in testing that the verification finished too fast to show this problem. I'll fix it.
  • Case
Reply #93
Fixed the bug and repeating line bug with long filenames. Compiled version can be downloaded here.
  • ktf
Reply #94
We're getting there Case! Great job, finally the characters show up. However, I still have a bug to report. I can't catch it in screenshots this time.
Suppose I run flac.exe with 2 files, like flac.exe -t ?????.flac ????.flac The first file shows up correctly:
flac 1.3.0pre3 [...]
?????.flac: testing, 56% complete
However, the second filename is not displayed
?????.flac: ok
testing, 12% complete
When finished, it does show the filename correctly:
?????.flac: ok
????.flac: ok
Another bug is the following: when a file doesn't exist, flac returns the next message
?????-n.flac: ERROR initializing decoder [...]
However, metaflac.exe returns something else:
αβγδε-n.flac: ERROR: reading metadata, status = "FLAC__METADATA_CHAIN_STATUS_ERROR_OP
ENING_FILE"
However, when the file exists, it works perfectly.
Still, I can't stress this enough, this is a *HUGE* improvement over no UTF-8 support at all, many thanks for fixing this
  • Last Edit: 08 April, 2013, 03:07:39 PM by ktf
  • Case
Reply #95
I should hire you as my personal beta-tester. I reverted the long-line repeating fix as it obviously needs much more work. Here's a fresh set with above bugs fixed: flac-1.3pre3-mod.zip
  • eahm
Reply #96
New Winamp 5.70 Build 3364 Beta 4
* Updated: [libFLAC] FLAC 1.3.0
Isn't too early to integrate FLAC 1.3.x?
edit:
Tag 1.2.1 20070917, same as the "Pre" versions.
  • Last Edit: 09 April, 2013, 04:33:41 PM by eahm
Reply #97
  • benski
  • Developer
Reply #98
edit:
It's a beta release of Winamp.  It's a good opportunity to test the FLAC release.
It's also worth mentioning that a vast majority of the changes for 1.3.0 were in the build scripts and the various tools.  The core libFLAC library only received a minor amount of changes.
  • Case
Reply #99
I uploaded a test binary with properly made long filename display fix. In my own testing it performs now correctly, but perhaps ktf could give it a try before I send patches to flac dev list. Download at the usual location.
