Topic: Can I prevent neroAacEnc from writing ITUNSMPB? (Read 3066 times) previous topic - next topic
  • Blaubaer
When converting a file to aac in foobar using nero it always writes a ITUNSMPB tag. This is not visible within foobar, but very well in MP3TAG via the extended tags.
Is there any way of keeping foobar from writing this tag?
I really don't want or need this tag and I find it very annoying. I simply don't want anything which relates to the foul fruit.
  • lvqcl
  • Developer
Nero encoder writes this tag, not foobar2000.
  • Last Edit: 02 March, 2013, 05:54:28 AM by lvqcl
  • Blaubaer
Thank you for the correction.
Then I will rephrase my question. How can I stop nero aac to write this tag?
  • skamp
  • Developer
You don't really want to remove that tag. It contains information to enable gapless playback.
  • Blaubaer
I know.
But I don't use apple devices and it is of no use on android or on a USB stick in the car.
I have been removing it manually ever since. But I am not really happy with this workaround.
  • Last Edit: 02 March, 2013, 08:21:04 AM by Blaubaer
  • lvqcl
  • Developer
NeroAacEnc 1.3.3.0 (and older) doesn't write it.
  • skamp
  • Developer
I don't understand what's the big annoyance. It's not like it even gets displayed.
  • lvqcl
  • Developer
http://en.wikipedia.org/wiki/Contagion_heuristic
The contagion heuristic includes "magical thinking", such as viewing a sweater worn by Adolf Hitler as bearing his negative essence and capable of transmitting it to another wearer.
  • Blaubaer
Yes, if you like I am showing charateristcs of a contagian heuristic in this respect.
I could indeed leave the tag where it is and live happily ever after, but I don't want to.
I simply feel uncomfortable with anything that has a leading "i".
  • Last Edit: 02 March, 2013, 11:16:00 AM by Blaubaer
  • nu774
  • Developer
Although Nero 1.3.3 uses chapter list + stts for gapless playback instead of iTunSMPB, you cannot stop it writing the string "com.apple.iTunes" into the mp4 box.
You will be able to find this magical string using Hex editor or something.
