Topic: How to install sox 14.4.1 in foobar 2000? (Read 11605 times) previous topic - next topic
  • hatrack71
I have an older version of the sox resampler in my foobar. Not even sure which version. How do I install the newest one to work in foobar and play mostly flac files? Will 14.4.1 even work in foobar?
  • Apesbrain
Read -> http://www.hydrogenaudio.org/forums/index....st&p=823001
Current version is 0.8.3 -> http://www.hydrogenaudio.org/forums/index....=67373&st=0
Existing discussion thread -> http://www.hydrogenaudio.org/forums/index....showtopic=67376
You don't need Sox resampler to play FLAC files.  Describe what you are trying to do and someone can hopefully help.
  • hatrack71
I'm only trying to upsample. I realize I don't need sox to play flac files. I was just wondering if there was any benefit to 14.4.1 for foobar over past releases. I have 0.8.3 already. When I ran 14.4.1, it installed two shortcuts on my desktop- sox.exe and wget.exe. I then went into program files to see what sox 14.4.1 had for components and found two. Do I just copy and paste them into foobar components or do I even need not worry about 14.4.1? Sorry if I sound like a newb, but I am.
  • Last Edit: 27 February, 2013, 10:58:18 AM by hatrack71
  • Rollin
You even don't need worry. "0.8.3" is number of foobar2000's plugin version and not SoX version.
  • Last Edit: 27 February, 2013, 11:28:16 AM by Rollin
  • Apesbrain
lvqcl's SoX Resampler uses its own DLL; those EXE files won't make a difference.  You'll need to wait until/if he/someone else updates it.  The first thread above suggests for now there is no functional reason to do so.  You're good.
The next SoX release is planned to have a faster "rate" routine, so maybe that will be reason to update:
http://sox.git.sourceforge.net/git/gitweb....angeLog;hb=HEAD
  • db1989
  • Global Moderator
Not because you mistakenly think it will improve quality, I hope.
  • bandpass
lvqcl's SoX Resampler uses its own DLL; those EXE files won't make a difference.  You'll need to wait until/if he/someone else updates it.  ...
No need, lvqcl's SoX Resampler is already up to date with the latest SoX source (even though SoX itself hasn't released it yet).
  • hatrack71
So which is the best version? The sox resampler, sox resampler mod or sox resampler mod 2?
  • Rollin
Modified version allows you to set a list of input frequencies that will pass through the plugin, unmodified. Or it can choose proper output frequency from the list.
*_mod: It doesn't resample the frequencies that you enter in the text field.
*_mod2: It resamples only the frequencies that you enter in the field.
