Topic: From Windows Explorer, how can I drag-drop shortcut files/folders to m (Read 1359 times) previous topic - next topic
Hello all, long time foobar user.. Foobar is usually very straightforward and easy to use and customize, but I'm currently stumped  .
Basically, I don't sort through my music collection in foobar. I have everything organized the way I want it in Windows Explorer, and I simply drag and drop folders and files from Windows Explorer into the Foobar playlist.
But I recently spent a lot of time making "compilations", where I simply made folders of SHORTCUTS that lead all over to their original files. I had no idea that I wouldn't be able to drag and drop these shortcut files right into foobar! I have to double click them individually, and then they will load into foobar.. so this means I cant say, select three shortcuts to mp3s and drag all three into the foobar playlist.
Is there any way I can do this? Some sort of change in foobar OR windows perhaps?
I'll appreciate any help I can get.. thanks!!
  • mjb2006
All you need to do install foo_lnk. Drag the .zip into your components (in the preferences).
thanks, that's a great find!
I installed it and while it works, unfortunately it only works one time. When I try to add a second shortcut, I have the original problem/(unable to play error), and have to re-open foobar to get it to add more shortcuts again. Any ideas?
It may sound silly, but when they say it requires foobar 1.0, do they mean I have to downgrade from my version 1.0.1?
  • Last Edit: 27 February, 2013, 12:12:32 AM by datooflessdentist
  • mjb2006
No, it's 1.0 and up.
I'm not sure what's going wrong with yours. It just works for me...doesn't matter if I do them one at a time, or the whole folder, or what. This is with foobar 1.2.2, DUI, Win7 64-bit. Are you using the default UI, or CUI?
  • Last Edit: 27 February, 2013, 12:33:35 AM by mjb2006
Just my luck
I'm running default UI, windows xp 32bit if that matters too.
I'll try it on my work computer tomorrow morning to get a better idea of whats wrong.
Thanks for the quick responses.
hmm, same problem on another computer.
Can only add shortcut(s) ONE time, then every shortcut I drag in after that gives me the error..
Any ideas what's going on here? Am I missing something? Perhaps something I need to change in Preferences?
