Topic: Soundcheck problems using different versions of iTunes (Read 1105 times) previous topic - next topic
I managed mp3 library imported in iTunes  with Windows XP and  iTunes 8.0.2.20 till last year. I always verified the Volume adjustment of each mp3 and the correlated hex values written in the field iTunNorm (using mp3Tag).
Last year I updated to Windows 7_64 and to iTunes 10.6.3.25 and went on importing new files in iTunes.
With some test, (same file imported using iTunes 8  and  iTunes 10 on  different PCs) I realized  that:
1.   iTunes 10 don't write iTunNorm tag anymore in the file mp3. I have a Volume adjustment, but with mp3Tag I can’t read any iTunNorm field with the famous ten hex values.
2.   iTunes 10 and iTunes 8 use a different way to calculate Sound Check; Volume adjustments calculated with iTunes 10 are lower of about  1,5-2,0 dB in average against iTunes 8. But sometimes  the difference may be very high (-5 dB or -7dB for example in iTunes 10 versus iTunes 8).
My questions:
i.    Where iTunes 10 write Sound Check info  to the mp3 file and how can I read it?
ii.    What can I do to avoid the discontinuity in Sound Check values due to the use of iTunes 8 and iTunes 10 without resetting all data?
iii.  What is the best: SoundCheck of iTunes 8 or SoundCheck of iTunes 10 (which is the difference)?
Thanks in advance for your answers.
