Topic: Few questions about Default UI (Read 2423 times) previous topic - next topic
First of all: hi to everyone
Lately I decided to make some changes to my Foobar config, which I have used for years. Created from scratch by myself upon the lovely fundamentals of Columns UI, there's some stuff I would like to move to my new config. Basicaly I try to do the same but with Default UI. And so far I have few questions.
1. Is there a possibility to add panels with specific informations and/or custom code (I used it for few things like listing additional tags I use and rating)? In Columns it was easy to set, in Default so far I could make some tabs no problem, but I don't see any option that I need and googling it didn't brough me any good information about components.
2. For playlist view I decided to use SimPlaylist. And it has some rating column in default configuration, but only with 5 stars. Any way to change that to 10 stars? Or how could I add track ratings from 1 to 10 in other way? In CUI I just made custom column, added some script ($if(%rating%,$repeat($rgb(255,215,0)☆$rgb(),%rating%)$repeat(☆,$sub(10,%rating%)),$repeat(☆,10))) and then in one of the panels I had other script for rating and it worked like a charm.
Thanks in advance for any tips!
(1) simple: foo_textdisplay , advanced: foo_uie_wsh_panel_mod
Great, thanks! Text Display will do for now, maybe will play around with the WSH too.
Anything about that rating? Or should I just make it from scratch again?
Also, new question, because I don't see the option for it: how to hide the column titles in playlist view/simplaylist?
Edit: ok, managed to find easy way to put back 10star rating into playlist view. Now to only figure out how to put the rating into text panel or WSH and be able to rate the current playing track from there. Any ideas will be much appreciated. And my last question still stands as active, no matter how stupid it may sound ^^'
ESPlaylist allows you to hide column headers and i *think* it has clickable ratings per track in the playlist
http://foo2k.chottu.net
It's always nice to have multiple good options, thanks for info! So far SimPlaylist seems the right choice for me, only if I could HIDE these column headers/titles. It's not much, but I always had it hidden.
Main thing for now is to create the rating "thingy". In my still current, old config it was simple: click for image. I had some script in that panel, it had hover effect and I could just rate it without a hassle. Now I could use the solution from nearby threat of Step by step guide (...) but rating through hotkeys or from rightclick isn't so good option. But maybe I'm missing something, need to read into that topic more.
