Topic: Classical Music (Read 1586 times) previous topic - next topic
  • DQ828
Classical Music
I am using Winamp but have been lured to Foobar by the good things I have read.
I listen mostly to Classical music & have Winamp main screen setup to list my music by Composer, then genre ie Sonatas, Concerto's etc for me the Artist is a secondary listing which I do use but it is not the most important search criteria for me like it would be for all of my other music which almost never get played.
The Composer criteria seems to be buried in the %artist%  field & for the life of me I cannot work out how to get my main layout screen to sort by Composer, can anyone point me to some info I how I would do this.
David
  • Last Edit: 20 February, 2013, 05:01:57 AM by DQ828
  • Porcus
Classical Music
For search, you can use composer HAS Beethoven. Note that there is a difference between artist HAS Beethoven and %artist% HAS Beethoven. The latter will include the composer also.
For the “main layout screen”: I suppose you mean the track list, where you have columns like Artist/Album Track Title/Track artist etc?
Right-click on one of these. You can choose between Columns and Groups. Choose Groups --> More. The next window lets you define your own custom columns. Try to call it Composer and with field %composer%. When you have gotten that to display as you want it, you can click on that column to sort by it (each time – but you maybe want that sort by default? But first step is to get it displayed, do start with that.)
  • Takaji
Classical Music
You could use Facets to create sort lists and sort by %composer%. Personally, my %artist% and %composer% tags are the same, as I consider the artist and composer to be the same. The performer obviously goes in %performer%.
This is my layout for classical music, using simplaylist: http://i.imgur.com/Uaa9PG0.jpg
Edit: This is assuming you're using the %composer% tag, otherwise you could sort by %artist% and get similar results.
  • Last Edit: 20 February, 2013, 11:05:05 AM by Takaji
  • Midiman
Classical Music
I am also a Classical person - my layout and instructions for how to use it can be seen here:
http://www.thewelltemperedcomputer.com/TG/MediaPlayer.html
I never bother with playlists per se - generally I just search for what I am interested in at the time and double click the item(s) to play them. Example: A search for "beet viol conc" will display all recordings I have for "Beethoven's Violin Concerto" - just click one and play it ;-)
Mike
  • Erich_2
Classical Music
  • DQ828
Classical Music
Thanks everybody  I'll check it all out.
  • DQ828
Classical Music
Ive managed to get a TAB Called Classical Music & a Composer view, but it shows all of the individual CD's that the composer is in, so whats the issue your thinking, with Winamp I am able to have a list of Composers  in one tab (only listed once each) and filtered so they are only classical music composers, then when I select the composer the adjacent tabs show the detail of all of the CD's that the particular composer is in. Is it possible to replicate this in Foobar?
  • DQ828
Classical Music
I worked out I can build part of the Winamp view in facets still working on it
  • DQ828
Classical Music
Facets appears to be the answer
  • Last Edit: 28 February, 2013, 05:42:12 AM by DQ828
