Topic: Merge "play" and "pause" button? (Read 2599 times) previous topic - next topic
  • o-l-a-v
Hi
Would it not be a good idea to merge the "play" and "pause" button in foobar? So that "play" is visible if a song is paused, and "pause" is visible if a song is playing?
That is more logical than the gui today + it would make the gui a little bit cleaner.
  • yanni
You're free to replace the buttons with one that maps to "Playback/Play or pause" instead (the command is already implemented in foobar2000, although it's hidden by default).
Don't know if you can make the icon switch accordingly, though.
  • eahm
No, because they have two different functions. If you play a song for 30 seconds and clic play again it will start from begin, if you pause/play it will start from where it is. I like this way better but you are free to change it like yanni described.
  • Last Edit: 17 February, 2013, 03:27:40 PM by eahm
  • EpicForever
You can both add custom keyboard shortcut to "play/pause" function (Settings -> Keyboard shortcuts) aswell as customize buttons and add custom button for "play/pause" function (rightclick on buttons field on your interface and choose ""Customize") . You can even give special icon (loaded from .ico file) to your new "play/pause " button.
  • Last Edit: 17 February, 2013, 04:11:26 PM by EpicForever
